Slee 4 or 6 inch?
TN
Can't decide on the 4 or 6" Slee lift. 35 inch tires are as large as I'm going to go for a long time. Im in TN so the trails are a little bit of rocks, mud and everything else. I'm leaning toward the 4 but would the 6" lift be to overkill to run the 35's?
Thanks
ERG80
I have the 6" and will be upgrading to 37's.
-Spike
Thanks for the replies. If anyone has pictures from the side of their cruiser with the 4 or 6 inch please post them up. No flex shots please i just want to see what the fender clearance looks like.
Like the one below stolen from Desertdudes ROTW. Thanks Desrtdude.
Where are you in TN? I have the 4" with 35's and a friend has the 6" with 35's, we are both in Knoxville if you want to come and check them out in person.
Darren
Here's a pic for you. I have since added a 1" spacer up front to even things out a little.
6" is visually way too much for 35's. They fill out the wheel well perfectly at about 4" of lift.
Look at it this way. If you do the 6", you'll be going nuts to have the tires look bigger, and then you'll be doing 37's. Just a little nudge to get that first domino falling...
Here's 6 inches with 295/75/16s
With the 6" kit you can run 37" in the future while a 4"/37" combination is a little bit tougher combination to do.
Diesel engine, Dual batteries, Factory winch, ~350#'s of gear in the back in the Irok pictures but no spare tire or carrier with medium rate Slee springs in the rear.
35x12.5x15 Pro Cop Xterrians, Wacky Japanese ~6" spring/spacer lift:
37x12.5x15 Irok Radials, Full 6" Slee kit:
I really would not want to run either a 4" or 6" kit without increasing track width though.
6"
35"
Sliders
Custom bumpers
Wish I'd a stayed at 4". Better wheel travel (up vs down), less tippy, added clearance not needed and front arms get in the way.
I definately wouldn't make my decision merely on what size tire you expect to run. Depending on geography one will probably be better suited than the other. I have a 6" Slee kit and DEFINATELY made the right decision.
Where (and how) I wheel, I drag some part of the underside of my rig every time out. This would obviosly be worse with a 4" lift. I also rub the rear wheelwells constantly. When I was in Moab for a week I only rubbed a couple of times. This goes to prove that the terrain has alot to do with what is best for you.
Personally I think that 35's look fine with my lift although I may go to 37's the next time around. Here a couple pics before and after the winch lowered my front end.
Just remember that both kits use the same OME L shock, so tires still compress to the same point. If you are going with the 6" kit, you really need to change the shocks to get the full potential out of it.
You never mentioned anything about armor. I would think this would be a big factor in considering a lift. Seems like most of these guys with the 6" and happy are also running with armor for the most part or are on their way to adding it when the dough rolls in. I believe Cristo designed the 6" for 35's with full armor even though he ran his Vlakvark with 37's. Also with a 4" you can always add spacers if your not totally happy with the results. I have just under a 5" lift with no armor and middle seats removed.
LUVMY80, I have thought about getting a moto-tote to put my KTM on the back of my 80 (going on 37's and slee 6") does yours get mushy with the bike on the back? I live in conifer so I do a lot of mountain driving. PS sorry for the non-subject related question.
I have the OME mediums with SLEE's old spacer design so from what I hear your setup will be a little stiffer. I also have air in the back but did not have it pumped up in this picture nor really need to in this case. I really don't think you will realize it is there stability wise. With the height your looking at you may need a drop hitch or have to back to a slight hill to help load and unload in some cases but it's never a huge issue. Your looking at an additional 3" than what I have which doesn't seem like much but after riding 90+ miles lifting 260 pounds that additional 3" sucks. The MOTO JACK is awesome for the 80 and seems to hold up fairly well while allowing for good clearance at the corners. I would also reccomend using tiedowns in addition to the peg holders, she gets a rocking back there without them.
6"
35"
You just need bigger tires!!!!:flipoff2::flipoff2:
look at Frankies off road 3.5" kit. Buy the other stuff that you may need or want from Slee.
