Shimmy @50mph
Southern California
Hey! has anybody experienced a shimmy from side to side after taking off the roof of your Fj40? When i hit about 45 to 50 MPH my truck starts to shake from side to side until i speed up to about 65mph. I never noticed it doing that before when i had the top off. The only other thing i did on the day i removed the top was install taller rear shackles , went from stock height about 2 3/4 " from center of pins, to about 5 3/4" center to center on pins. So it's either one or the other, or maybe a combination of both causing this. Just thought someone else had the same issues and could let me know
I had a shimmy at about 63 mph, smoothed out at 70 mph (softtop)
went away after balancing and adjusting air pressure to be the same in all tires :rolleyes:
Extended shackles change the caster angle on the front, and the pinion/driveshaft angle on both the front and rear. The caster angle is an important contributor to shimmy and wobble, but there are many other things that can contribute also.
I had sudden and extremely serious shimmy after taking my top off.
Turned out that most of the tires were out of balance, two of them quite badly.
None of the weights had been knocked off. Just a lousy job had been done.
It sounds odd, but the shimmy was not noticable until the top was removed. That removed about 250 lbs and probably made the tub less stiff. The top of the windshield and the forward top of the roll cage were oscillating over an inch past each other at a pretty high rate of vibration. The front wheels were wobbling keft and right at the same rate. I didn't see or feel any up and down travel.
We thought that the caster angle was off due to the installation of 3" taller than normal shackles in the rear, plus the weight reduction of the top further increasing the rake of the vehicle. Caster shims did not help and were removed.
Out of desperation, and thanks to suggestions from ih8mudders here, the tires and wheels were balanced. And that's when the bad balancing job was discovered. What a night and day difference it made. Not a trace of shimmy whatsoever now.
That's not to say that I don't have caster issues. But I won't address those until the top is back on and I simulate the weight of a winch up front and install longer shackles up front. Likely much shorter than in the rear.
Hey Brian, what you experienced on your rig sounds exactly what i have on mine.I think i will get the balancing checked out and also try adding taller shackles on the front to compensate for the caster change.
Thanks for all the info
I wouldn't put longer shackles on the front without adding caster correction shims. If you didn't fool with the front, caster is not likely to be much of an issue, but it will be if you install longer shackles.
first of all, it sounds like a resonance problem!! it appeared probably 'cause the top was doing the job of a kind of damper. I would recommend checking the engine, gear box, and all the parts that vibrate for any loose screw and if the rubbers of them are ok. Of course wheel aligning and balancing.
My .01 cents...
Also check the rear output shaft: disconnect the rear drive shaft and see that it does not wobble at all. I have had that issue in the past, and that was the culprit.
Again, my .01 cents only.
I had the same problem and had the tires balanced which helped some, but I finally took it back to a different alignment shop last Saturday and they showed me that at lease one of my wheels is out of round.
They also showed me that the previous balancing shop had lined up 8 1 ounce weights on the inside of one wheel instead of using one or 2 heavier weights, which probably made it even worse! I think I won't take my truck back to Firestone anymnore...
Brian in Oregon said:
LOL, it was Firestone that corrected my balance problems. Evidently it's not a chain issue, but an individual franchise problem.
I think it's probably a training issue. I had my tires balanced at the shop of a family friend in my hometown who I had been doing business with all my life. I brought my tires back one time because of a balance issue and when they took the tires off, they discovered that whoever had balanced them had put a weight on opposite sides of the wheel, thus counteracting the effect of the weights. To his credit, he gathered all of his "technicians" together and showed them the wheel and said that this was unacceptable and explained what the problem was.
I get the idea that there are an awful lot of "Technicians" that come off the street and are never given any formal training on how the machines work or the theory behind them. That's why, when I find a place that does a good job, I'm pretty loyal.
Having the tires balanced is a good first step. Personally I doubt that it's something as substantial as an output shaft. If it persists once the tires have been balanced, my next step would be to check the steering components. If you still have the factory manual steering the center arm bracket could be worn and in need of a rebuild. The tie rod ends might also be loose. Also I would check your spring bushings. Suspension is not always a consideration with a problem like this but I have found it's very common. I had some serious wobble/shimmy in my 40 and chased it for a while only to find that my spring bushings were worn and the shackle/hanger bolts were loose. Tightened them up and no more shimmy.
Good luck.
