Bad wheel shimmy after removing top & doors
My 71 FJ40 suddenly developed a bad case of the shakes at 50+ mph after removing the hard top and doors. I thought it was trying to shake itself apart. I searched and read all FJ40 threads for "shimmy". I'd still like advice. It has a set of Rancho 2.5 inch lift springs all the way around.
Initially, the rear squated a bit, because it has a smallblock Chevy conversion, which is lighter than the original six. The rear wheels also fouled the wheelwells, because they're on the large size for uncut wheelwells. I added 3 inch over stock shackles to the rear. The front shackles are stock. The truck sat with a slight rake to it with the top and doors on. It has more of a rake with all that weight off.
With the top and doors on, it steered beautifully. It actually felt like power steering, almost effortlessly. Reminded me of driving my old MGB sports car, at least for steering effort. With the top off, it still steered nice, but the shimmy at 50 and bove was horrible. I was told that the rake was causing the caster angle to go negative, which made it easier to steer, but also made it easier for the road to influence the tires and set up harmonic vibration. It was suggested to put in six degree shims. I already had them on hand, since MAF suggests that angle for a 3 inch shackle lift. Even though the fronts are not shackle lifted, the Cruiser sits at an angle because of the rear. OK, got them on the front, big end forward.
Three things became quite apparent:
The steering takes a lot more effort. Like a stock cruiser.
It wanders in turns and understeers - it had neutral steer before (neither over nor under steer).
And the shimmy can be felt slightly starting at 40 mph and is still bad at higher speeds.
The steering compenents were rebuilt a few years back. They do not have high mileage on them, and seem to be in reasonable condition, with the exception of the steering stabilizer, which appears to be original. Some of the searched posts say this item is simply a bandaid and others say it is a major part of resolving steering shimmy. What's the deal here?
Have I put too much rotation on my front axle? Or perhaps I should have left it alone and done something differnt?
BTW, as per the other threads, I did make sure the wheel weights are intact on the wheels, and there is no wheel damage, and they are clean.
Hi All:
I cannot think of how removing the doors and hard top could produce a "shimmy" in the front suspension and/or steering! If anything, I'd say your 3 inch over stock shackles in the rear are probably causing the rear drive shaft u-joints to operate at a more severe angle than before, which can produce a bad vibration.
Good luck!
Alan
Removing the doors and top removed something like 250 lbs of weight, which reduced the load on the springs, especially on the rear. As a result, the rear is even higher than it was before. This increased the rake of the vehicle, which increased the rotation of both axles. The before and after difference was sudden and startling after the doors and top were removed. The axle rotation, driveline angles, caster, or simply the lack of weight on the front end must have been at the borderline limit before the top and doors came off.
Josie'sLandCruiser said:
Hi All:
Good luck!
Alan
I suppose in order to really make this analysis fair, you should put the top and back doors BACK ON to see if the condition is truly temporary, or a permanent deterioration.
Beyond that, I think Alan's theory makes more sense than hardtop induced caster issues.
Good luck
Mark A.
While it is possible the rear driveline angle could produce a vibration, please clarify whether or not it will produce front wheel shimmy. I've never seen that as a result of rear driveline problems.<br>
<br>
We can clearly see the front wheels oscillating, and I can feel and see it in the steering wheel.<br>
<br>
Put the top on or find something around 250 pounds...Sand, parts, a friend. Then drive it again.
It really sounds like a castor angle issue. Have it aligned recently? Unbalanced tires will make your wheels oscillate also...
Also can you snap some photos straight on from the front and back of the vehicle. Also a side shot..
edit: you could have thrown a wheel weight up front around the same time as the top..it could give you issues as well.
Sounds like the shimmy is a coincidence although anything is possible.
Make sure that you've got toe-in, change the steering dampener, adust everything - wheel bearings, steering box, center gear. Don't assume that a tierod end is tight just because you can't feel movement by hand.
Brian in Oregon said:
. . . It was suggested to put in six degree shims. I already had them on hand, since MAF suggests that angle for a 3 inch shackle lift. Even though the fronts are not shackle lifted, the Cruiser sits at an angle because of the rear. OK, got them on the front, big end forward.
And this caused your cruiser to be harder to steer and want to track straight forward even while turning? It sounds like you may have over corrected for castor.
This is a left/right oscillation?
I agree with the others that you need to test drive with the top back on. This way, you may determine whether top removal was cause or coincidence, and, if it's the latter, start looking for the real problem.
It's quite possible I overcorrected the castor angle. Might have been better to get 2.5 and 4 degree shims as well and have a shop with a machine set the castor angle.
Correct, this is left/right oscillation of the front wheels.
We do not see up/down bounce, combined with no areas on the rims that appear to have lost their wheel weights. However, it's an easy matter to have a tire shop recheck the wheel balance.
As for putting the top back on, I have plenty of stone wall blocks. I can easily add 250 lbs of them in the bed and get a heavy adult to ride up front with me. I don't particularly want to reassemble the whole top, since it's completely apart.
The top and doors add a certain measure of "stiffness" to the body--but not THAT much. I wouldn't think taking them off would make the difference.
Auto designers who build convertible versions of sedans end up with stiffness problems too. A roof and top bolted to the chassis changes weight distribution and torsional stiffness of the entire unit.
I just took my hard top off weekend before last andI have the exact same issue! I also have the same Rancho (rauncho) suspension that will jar your teeth out on a good day...
I got my wheels balanced after the steering oscillation started to see if I had lost a weight, but it didn't entirely correct the problem. A couple of days ago I swapped one of the front tires to the rear to see if maybe one of the belts had sipped in my tire. That seems to hav helped quite a bit, but that doesn't answer the question of why it started when I took the top off.
I think the vibration in the tire must have been there before, but the weight of the top made it not as niticeable before. I bought the tires used so it is entirely possible that when I got them mounted, the shop swapped 2 or more of the tires side to side causing the belts to slip.
I have noticed since I swapped the tire, that even though the oscillation is mostly gone, I feel every bump in the road now. I really want to get rid of the Rancho suspension in favor of an OME one that will ride softer, but I can't afford it in the near future.
I'm glad to find out that my experience isn't unique. At least I don't think it's just a coincidence anymore.
HTH
Coolerman said:
In the FJ45 section (buckroseau's thread) there was a post about death wobble that was possibly caused by loose axle u-bolts. Might pay to give them a once over?
That scares the hell out of me!
Mine is sitting outside my office right now waiting for me to drive it home. Hope my axle doesn't fall off on the way...:rolleyes:
Actually mine is a lot better since I swapped the tore to the back. It still rides really hard, though. I think it's just these hard Rancho springs. They were pretty bad before, but now with the reduced weight they're even worse.
Thanks!
In the past I have found that tightenig the ubolts cured my wobble, along w/making sure the shackles were snug too!! I am running about 5" of lift, so I'm sure my caster angle was minimal at best. Tighting the ubolts did cure the problem. I have also noticed that putting in a degree shims work but will eventually break the center pin and the ubolts will loosen. I ended up welding the shims to the housing so it would assemble similar to the stk configuration and the ubolts now stay tight.
I had those Rancho springs in the early 80's. 3 Leaves? I can't believe they're still around. The main leaves finally broke. Life is good now!!!
...Im laughing as I am sitting hear reading this thread. I actually just turned my computer on to leave a post on this issue and get your guys opinion. Yesterday I finally was able to remove my top from my 1970 fj40. I took it for a spin and when I hit about 45mph the thing started shakeing like crazy. At first I thought that i was loosing a front tire. I pulled over to the side of the road, and inspected all my U-joints lug bolts, steering ect,ect. Seeing as I couldnt find anything wrong, I hit the road to head home. Im running 38.5 swampers, the tire ware must of thrown the balance of the tires off, and the added weight of the top must have put just enough pressure on the front tires to correct the balance issue... this is what im hopeing anyway. I made an appt with tire shop to have them balanced on sat...
I also have Super Swampers on my truck and (as you can see from the post above) had the same thing happen when I took my top off a couple of weeks ago... I am thinking I may have had a belt slip in one of my tires. I had them balanced and it helped some but it helped more when I swapped one of the front tires to the back. I still have a slight vibration when I get to around 50 MPH so I'm thinking of swapping the other tire to the back to see if that cures it.
My tires are 33s, I can imagine how much worse 38s would be, since they are probably a good bit heavier.
My Rancho springs aren't 3-leaf. The front is 6-leaf, p/n RS43033. This and the rear RS43044 are their 2-1/2" lift springs.
At the very least will order a new dampner. Probably an OME unit. Not sure what else needs replacing at this point, nor have I checked the balance of the tires. We've had almost non-stop monsoons. The Cruiser is wrapped up under tarps right now, since it has no top at all.
And the u-bolts are tight. I had to take the bolts off to get the shims in, and they were TIGHT. And they're tight now.
FIXED!!!
Stopped pouring rain, so I took it in and had the tires checked for balance.
Only one tire was OK. The others were all off. Especially the front tires. Both of them were badly off.
The driver's tire needed SEVEN OUNCES on the inside and TWO ounces on the outside to balance it. The shop rotated the tire in the rim 180 degrees and drastically cut the amount of weight it needed.
The passenger's front tire wasn't quite as bad, but it, too, had to be rotated in the rim 180 degrees to use less weigt.
One rear was OK. But the other rear and the spare were off. They did not need to be rotated, but needed to be balanced correctly.
Took it out on the freeway, and the "death wobble" is completely gone!!! Smooth.
We're wondering if the PO or his kid might have aired the tires down and possible rotated them in the rim. I had the tires rotated a few months ago, but no vibration showed up until the top and doors came off.
I'm going to pull the six degree castor shims out, and install a new steering dampner (probably an OME - comments?). Will also install new shackles in front, a job I've put off. Will start collecting all the parts to do a front end overhaul sometime this summer.
FIXED!!! I had the tires rotated a few months ago said:
my axeles started to leak so Ive been workin on those... I havent had time to take the tires to get them balanced...but its great to hear it was the cure for you..im hopeing the same thing will happen with me....
another weird thing is, after i got the "death wobble" my front passanger side axel started leakin (same side as the wobble)...im gonna tackle that tomorro....I guess I should have never taken my top off :rolleyes: ......times tickin untill the Rubithon....after I fix this...it aint movin untill it goes on the trailer for the event..:D
Well, I swapped the other fron tire to the back and that got rid of the wobble. I may need to get someone who is a little more "committed" to balance them, right. The guys at Firestone didn't mention anything unusual about the balancing they did to my tires so I figure they did the minimum they could do to say they did it.
I still have a bit of vibration in the truck which is, I'm sure, due to the vibration in the tires that used to be on the front. I'd like to get the thing right, since I have to drive at highway speeds to get to our meeting next Tuesday...
