You would cut the gate...and then just push the shift lever to the passenger side, not pulling it rearward. That would give you 2WD low.
Could you tell me what kit you bought from AA , I have a 76 FJ40 with stock 4 speed and stock transfer case , i cant seem to figure out what kit i need
Thanks Robb
Call AA and they will tell you which kit you will need. I believe they all cost the same, just have a few minor parts differences.
Stock fing birfs will fail....this will not prevent that...keeping the truck on pavement and not using the front axle is about the only thing that will prevent the fing birf from failing.
This mod can be done to your shift gate/bracket as well.
exactly what i did to mine, my shifter is tighter than before when i was using the plate ,it used to vibrate and rattle all the time ,now with a few washers on there it is smooth and rattle free .
Just out of curiosity, what would the effective shift pattern be? I'm having trouble visualizing this right now. I've never had a twin stick setup. I might do this tonight.
I never did see the twin stick idea as a bonus cause it just seemed to clutter up the floor and I already had the 2low capability with one stick.
One stick is simpler, less parts, and it is already installed.
Actually, it was NOT possible even on the older vacuum-actuated front drives. There was a mechanism on the hi-n-lo lever that automatically actuated the front drive when you moved from hi to lo.
Which is fine for a stock trans and tcase combo, but if you were to change drive train, V8/auto trans, etc, you will find that trying to keep the stock shift lever configuration to manipulate the transfer case may prove to be a more problematic than fabricating or purchasing a twin stick set up.
Imagine a square shift pattern.
H2---L2
H4---L4
You can travel along any of the sides of the box but not across the center.
crappy pic . this is a pic of an sm465 with a 4sp. linkage .threaded into a piece of flat stock bolted to the side of the 465 on a 3sp.t-case .,can see the fat washer on the end .just sandwiched it a bit tighter .. got a pic of where u are talking about?
Yeah, I know it's an ancient thread, but does this mod work with a split case too?
Dedtruk...Im looking for answer to this question too. I have the tub off the frame now and therefore never as accessible as now.
Remove the gate, add washers to fill the gap,...DONE!
Best
Mark A.
