Saginaw plates
Saskatchewan
After looking at the Saginaw box on my work bench for the last 3 years I have finally got some time to do this install.
Lots of kits and plates have come and gone since I bought this box so my question is.
Who is making a nice set of resonably priced plates these days?
I have decided against the bracket style that welds to the frame and want to go with the plate instead.
I don't understand the question. All of the normal options weld on to the front frame horn, if you are using a normal Saginaw box. If you are using a scout box, then the mount is on the frame rail near the shock mount. As far as I know, all of the options involve welding.
I just want to know which plates work best. BTB, Marks ect.
I understand that I will be welding.
I want to know what people recommend for a quality kit.
In that case, you have a bunch of options. BTB did a bunch of work on my Cruiser before I owned it. None of it was done that well. When I called just to ask about it, I got the run around. Since then, I have refused to deal with them or reccomend them. They likely do good work now, since they get such a premium price for it.
I used a Warden steering plate for years. It works great, and I believe is exactly the same style that Poser on this board sells. Poser puts a lot of time and effort into his stuff, and you could buy it with confidence.
I recently re-did my steering conversion and went with the 4X4 Labs version. It mounts the box a little higher and tucked in a bit more to the cross member. The plate cames with the frame boxing and re-enforcement kit. I really like it but it's a bunch more money than Poser's plate. Pics if you want.
All the ones I have seen are plate mild steel. I have heard there is a cast piece, but I've not come across it. If you are going with Poser's plate, you'll be happy.
I have orange45's plate on my 45
Kurt with Cruiseroutfitters has a good product. All in one kit.
If your cutting through your crossmember you need to sleeve it.
got my stuff here as well, local and all.
sleeving is easy and will add about 10 minutes to your mod time, well worth it.
and mine is stuffed as far into the cross memeber as possible
