I'm baffled how this can even be considered to be something coming from the exhaust?????
I think it is the oil pump drive gear. Put your stethoscope on the oil pump to check it. You can also temporarily remove the PS pump and see if the gear is flopping back and forth.
Ouch.You need to replace the timing chain cover, which means dropping the oil pan and removing the head. It is a lot of work.
What has worn to the point that the oil pump drive gear could flop around inside the pump housing? I am curious as mine is at 271K and doing well but education is always good.I think it is the oil pump drive gear. Put your stethoscope on the oil pump to check it. You can also temporarily remove the PS pump and see if the gear is flopping back and forth.
If it is indeed the oil pump drive gear, I would imagine it could go a long time making noise like that. The knocking is oftentimes caused by a tiny nick or ding on the power steering pump gear, so replacing the PS gear might make it go away.
I would consider getting a new timing chain cover for your new rebuild.
The thrust clearance is set by the timing chain cover. As the aluminum wears, the gap increases and the gear can flop back and forth. The wear limit and how you check it is described in the FSM.
Mine has made that had that exact noise intermittently for about 4 years. Maybe once or twice every 6 months. Only when cranking up in the morning and goes away after 1 mile of driving. As bad as it sounds, I have never investigated because I have had plans of doing an LS swap when it blew, but it keeps on trucking along. I'm tired of waiting and engine is being pulled for swap in the next couple weeks. Lol.
Replace it with a 3fe because they're more betterI won't be doing another LS swap... I'll swap in my rebuilt 1FZ-FE. Just trying to decide how crazy deep I get in to rebuilding it. It has 153k on it. I'm thinking I will replace all seals/gaskets. Have the head checked. Anything else? Do I NEED to do other stuff?
Seems to be the general area where my noise is coming from...had thought it could be power steering pump as well, i sourced a solid take out motor and transmission today so looks like i will be swapping in the not to distant future...I think it is the oil pump drive gear. Put your stethoscope on the oil pump to check it. You can also temporarily remove the PS pump and see if the gear is flopping back and forth.
