Hi all,
I've been bouncing this topic around in a few other threads but I figured it was probably time to give it it's own home. I've got a set of engine mounts in hand and I'm trying to figure out the easiest way to swap them in. Has anyone done this yet with the engine still in the truck?
I'm hoping that I can remove the air cleaner tube, the bolts that hold the fan shroud and heater valve in place, the upper and lower rad hoses, and if I have to the four nuts holding the exhaust downpipe to the manifolds, and then jack the engine up enough to swap the mounts. I'm not sure if there is enough room in the transmission tunnel to get the engine to clear the studs on the mounts.
The other idea I have (suggested to my by Andrew, "The Lovely Boyo") was to do the mounts one at a time. Loosen one mount and pivot the engine on the other mount to open the gap. This might involve removing the mounting brackets from the engine though.
The last thing I'm wondering about is how to lift the engine. I plan on strapping the front axle to the frame first to minimize the effect of the front springs, but I'm not sure where to jack or hoist from. The obvious answer up top is the front engine hoist bracket (right?). Underneath I have heard of folks jacking up the crank pulley or the edge of the upper oil pan where it bolts to the block. The other place I thought about is the block-to-transmission mating point since it's fairly wide and flat.
I'd appreciate any input or previous experience before I try this myself.
Since everyone likes photos, I've borrowed a couple from concretejungle's https://forum.ih8mud.com/80-series-tech/432477-1fzfe-overhaul.html thread to show what I'm talking about (I hope you're not reusing that pillow case when your transmission is done with it!
