Replacing the engine mounts
I replaced all three a few months ago and have had no issues. Strangely though, when I have my hand on the gear shifter, I can feel it moving around when I go over bumps and dips. Sometimes more than a couple millimeters.
My gearstick (5 spd manual ) has always been very 'floppy'. Didn't change a bit when I had the gearbox replaced with a fully rebuilt one just over a year ago. I don't know what the auto box shifters in 80's are like.
Given that the manual gearstick length 'accentuates' all the engine movement/vibration that isnt surprising. I can't work out if theres anything I can do to 'tidy' the gearstick movement (which would help make gear selection smoother). There doesn't seem to be any part of the manual stick apart from the nylon 'cup' that wears appreciably.
To change the mount under the transfer case I supported the box and transfer with my trolley jack and a lump of wood, then unbolted everything so I could drop out the crossmember. I gave that a full clean while out from under the vehicle.
pic page
Can the transmission mount or isolator be removed and installed without loosing anything else? Just get under the vehicle and raise up the transmission and loosen nuts removal and install? If not any recommendations on how to replace when doing only the transmission mount and not the two engine mounts?
Yes, I believe that is what @sunrk is saying.
