We've been replacing rear-end components damaged by a former owner to get the truck straight and level.
After replacing a bent trailing arm and a leaking KDSS cylinder ($$$) the alignment tech noticed the rear axle is offset 1" to the side. Factory spec allows for 1/2" with stock configuration.
I was wondering if perhaps the OME BP 51 suspension lift could be responsible for the change in the axle location? Makes sense if you start playing with geometry things would reposition.
If not, time to inspect more components.
Anyone with experience in this?
