I did Pre-Supercharger and Post-Supercharger dyno tests.
Here is some info that may (or may not) affect the data, but thought about letting everybody know to clear some of the potential questions.
I bought the LC on March 01, 2007 with 153,000 miles on it (all stock). It was in great shape and ran great. I immediately changed all the fluids to synthetic, and did some initial PM.
Some of the things that I did that may be relevant to this thread: At 154,635 miles changed thermostat, new radiator cap, flushed Toyota Red and installed Freeztone Green, installed new spark plugs, installed K&N Air Filter, new fuel filter. Installed Yellow Top battery(160,300 miles). Installed Blue Fan Clutch (165,191 miles).
Before the S/C (at aprox 100F outside temp) the Water Temp was consistently 200F +/- 5F, even after I installed the Blue Fan Clutch (I did not see a huge improvement). In average I was getting 11.28 MPG, and were using regular unleaded fuel (87 oct)
When I installed the S/C I did some “while I was there PM”, this included: changed crankshaft seal, fixed Oil pump cover leak, new valve cover gasket, new spark plug grommets, new PVC valve, distributor shaft o-ring, cleaned K&N filter, recalibrated spark plugs, and changed Eng Oil and filter.
I installed the entire S/C kit with no mods (166,022 miles). With the S/C I have not seen the Water Temp change too much (during the same 100F outside temp). However, cruising at 70 MPH (aprox 2,400 RPM) the water temp is consistently at 205F, but comes back down a few degrees at lower RPMs. With the S/C I am getting 11.07 MPG and now I use 91 oct or better.
