LinkBack (10) Thread Tools Display Modes
Old 02-10-08, 05:41 PM   10 links from elsewhere to this Post. Click to view. #1 (permalink)
SF80's Avatar
Hellroaring Dual Battery Install
First of all, I would like to thank everyone on Mud for the information in the forums, helping me with my Hellroaring dual battery install. Thanks to Romer for the FAQ and his remote idea. Special thanks goes to Cruiserdrew and his write-up (most of his install I've blatantly stolen pointers for my install).
I decided to start this project in anticipation of an ARB bumper and Warn 12k winch. I will also use this system for a future inverter and extra 12v accessory outlets.
Here are more higher res pictures of the install.
The parts:
  • 2 Group 31 Optima Marine grade batteries (amazon.com)
  • FJ80 PS Battery tray kit from CDan
  • Hellroaring isolator/combiner
  • 150 amp ground fuse block (from mike at hellroaring)
  • Slee washer bottle relocation kit
  • 10 ft 1/0 gauge marine grade cable (west marine)
  • 4 ft 2 gauge marine grade cable (west marine)
  • 4 ft 8 gauge marine grade cable (west marine)
  • 4 marine grade terminal tops (west marine)
  • bunch of 5/16, 3/8 & 1/4 lugs & shrink wrap from custombatterycables.com
  • rattle can primer and black engine enamel paint
  • various small electrical connections for the hellroaring remote
It took about two weeks to source all of the parts (had to order all of the lugs last to determine the size of all of the posts.)
Brian
'95 FZJ80 | Emerald | locked | Slee 4" & BFG AT 315's | Hellroaring Dual Battery | 150 amp-ed | MAF-ed | Scion-ed
'08 BMW 135
SF80 is offline   Reply With Quote
Old 02-10-08, 05:58 PM   #2 (permalink)
SF80's Avatar
The first step was to de-grease (brake cleaner) and lightly sand the two metal brackets from the Slee washer-bottle relocation kit. Then I applied 2 thin coats of rattle can primer followed by 2 coats of black engine enamel.
In between paint coats, I had a good opportunity to remove the air filter housing (3 12mm lower mounting bolts & 2 10mm hose clamp bolts). I also removed the washer bottle (3 10mm bolts) and disconnect the power harness. The Slee instructions recommended emptying out the washer bottle. I recommend just taping the hose up above the washer level (or you can just wrap the hose around the filler cap.)
You have to cut the 2 wires that feed the washer pump to extend the line back to the new washer bottle location. I cut the wire about 4" behind the plug. The slee kit comes with 2 new extension wires, and I used the shrink-wrap with solder center connections to join the 8 ends together.
By this time the Slee brackets were painted and dry. It is not obvious from the instructions what the orientation of the washer brackets should be, so it took about 5 minutes to figure out.
Picture 1 is the inner lower bracket that holds the left side of the washer bottle.
Picture 2 is the upper outer bracket that holds the right of the washer bottle.
Brian
'08 BMW 135
Old 02-10-08, 06:14 PM   #3 (permalink)
SF80's Avatar
The next step was to install the new battery tray kit from CDan.
This kit consisted of the battery tray, OEM battery tray bolts, j-hooks, hold down bar, hold-down nuts, and even battery cable hole rubber grommets. VERY complete.
Step 1 was to trim the battery tray so it would fit in the location. The front inner (right-side) has to be trimmed back about an inch and a half following the contour of the radiator. I used a jigsaw on slow speed to cut the tray, as CDan told me that there is fiberglass in the tray and had warned against grinding.
I then had to lower the high-pressure AC line to get the tray to fit height-wise. I simply removed the rubber bushing and that netted me enough height to position the tray.
I also had to use a step drill bit to "open up" the 2 lower mounting holes in the tray to get them to line up with the holes in the fender.
The new tray will dislocate another wire harness that I ended up mounting to the battery tray.
Picture 1 is the shifted AC line
Picture 2 is the trimmed battery tray
Brian
'08 BMW 135
Old 02-10-08, 06:30 PM   #4 (permalink)
SF80's Avatar
Ok, next I mounted the hellroaring and ground fuse block.
I chose the very outside of the back of the new battery tray to mount the hellroaring (same place as cruiserdrew). The location of the air filter forces this location taking into account cable lengths and ground location. I only used three nuts and bolts to mount the hellroaring because I could not find a position on the tray that had flat spots under all of the hellroaring mounting holes (the battery tray has many corrugations that makes it difficult to find a good flat spot.) It is still very secure with three bolts.
I mounted the 150A bussman ground fuse block to the other back side of the new battery tray.
I made sure I used washers behind the battery tray for the hellroaring and ground fuse mounts as it is fiberglass-embedded plastic.
Picture 1 is the mounted hellroaring (note the relocated unknown wire harness)
Picture 2 is the mounted bussman fuse
Brian
'08 BMW 135
Old 02-10-08, 06:56 PM   #5 (permalink)
SF80's Avatar
Ok, now on to the wiring!
I started with the new battery ground and ground fuse. I used 2 gauge wire and the heavy-duty lugs from custombatterycables.com for the engine ground. I used my buddies impact crimper to crimp the cables to the lugs. I found out that the shorter the cable run, the more important it was that the lugs were in the right orientation (spin) on the cable. Many of the lugs ended up being in a 90 degree orientation to achieve the right position.
I chose the upper-right boss on the engine block to make my ground connection as this kept it away from the exhaust manifold.
The next step was to wire up the positive leads from the new battery to the hellroaring. This was particularly difficult due to the 1/0 gauge wire I chose. The close-quarter bends to make the short distance to the helroaring took a bit of time and wire wrangling. Componding this was the wire lug size and the close position of the hellroaring posts to each other. I had to grind down the lugs to make sure they did not contact each other when the are mounted on the hellroaring. This is not ideal, but I will monitor and make sure there is no touching issues in the future.
I then ran the cable lead from the hellroaring to the positive buss of the existing system. I chose to wire the hellroaring output directly to the positive post of the main battery. I know many people have run this lead to the positive terminal of the starter or alternator, but for me the main battery was the most obvious.
I also temporarily ran the cable on top of the radiator core, but I would like to route it under the core support where I ran the Slee headlight harness.
Picture 1 is the hellroaring wired
Picture 2 is the front view of the two batteries installed and wired
Picture 3 is the side-view of the two batteries installed and wired
Brian
'08 BMW 135
Old 02-10-08, 07:16 PM   #6 (permalink)
SF80's Avatar
Lastly, I installed the hellroaring remote.
There is an existing grommet from the engine bay to the cab up and to the left of the pedals on the driver's side. I fished the three remote wires through this grommet and ran the cables along the back of the engine bay around the new washer bottle location and then over the top of the PS wheel well.
The hellroaring kit comes with two 3A fuses for the positive and ground leads. I decided to shorten the length of the wire between the hellroaring and the fuses for accessibility reasons. This was easy as the helroaring comes with clip-in fuse holders that makes it a breeze to customize the length.
I ran the hellroaring engine bay ground to the chassis ground that is used to for the engine ground. I uses the ECU mounting bolt in the driver's footwell to ground the in-cab remote ground.
I used Romer's idea to re-use one of the dash blanks to mount the three-way hellroaring toggle and indicator LED. All that is need is to cut open the hellroaring remote box (to not have to discconnect the remote leads) and drill out the dash blank for the toggle and LED. I found it best to use the original remote box to determine the best bit size for the blank. I did up-size the hole for the LED as the blank plastic is a bit thicker than the remote box was. This helped to bring the LED further forward in the blank.
The remote toggle and LED are easily fished with a coat hanger from below if you use the same location that I did.
Picture 1 is the opened hellroaring remote
Picture 2 is the assembled blank
Picture 3 is the installed blank
Brian
'08 BMW 135
Old 02-10-08, 07:45 PM   #7 (permalink)
Cook Free or Die
alvarorb's Avatar
TLCA# 12833
Brian,
Very impressive. Good pics too.
Congrats
Alvaro
Alvaro Rodriguez
96 FZJ80 "La Cabra"
08 Tacoma Double Cab 4x4
TCLA #12833 / BRC # 41799
KI7FZJ
New web site with blog and pics
Norcal wagons website
Color Blog
Make a loan, Make a difference - Kiva.org
alvarorb is offline   Reply With Quote
Old 02-10-08, 09:16 PM   #8 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Excellent write-up. I am going to add the link to the dual setups FAQ
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 02-10-08, 09:25 PM   #9 (permalink)
Addicted to MUD Porn
locrwln1's Avatar
TLCA# 16879
Very nice. I need to get mine done. I have the battery tray and second battery, just haven't wired anything yet.
Jack
KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster)
locrwln1 is offline   Reply With Quote
Old 02-11-08, 08:20 AM   #10 (permalink)
Angel?'s Avatar
TLCA# 16516
Sweet. Great job!
Cal
W6CRH
South San Francisco Bay Area
Los Gatos / Monte Sereno, CA
1994 FZJ80
Angel? is offline   Reply With Quote
Old 02-11-08, 08:35 AM   #11 (permalink)
Nice work!
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 02-11-08, 08:47 AM   #12 (permalink)
Zemsta!
Polak's Avatar
TLCA# 15431
Ooooo La La!!
What were your resaons for going w/ the marine grade batteries besides the extra posts?
Very nice work!
Polak
'96 FZJ80 OE Lockers, 2.5" OME Heavy, 285/75/16 Nitto Terra Grapplers....
'75 FJ40 SOLD but not forgotten
Polak is offline   Reply With Quote
Old 02-11-08, 09:14 AM   #13 (permalink)
LockedLX's Avatar
TLCA# 8675309
Thanks for the detailed write-up!
'97 LX450 - 136k, tree & rock enhanced
'95 Volvo 854 Turbo - 265k, highway star
Originally Posted by SUMOTOY View Post
I just mathed boost is *exactly* the same as gearing Ken!
LockedLX is offline   Reply With Quote
Old 02-11-08, 09:42 AM   #14 (permalink)
grown up MOD
reffug's Avatar
TLCA# 14549
guess this is a start for my reading on how hellroaring works................
since I need to increase my knowledge in this area.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
reffug is offline   Reply With Quote
Old 02-11-08, 09:45 AM   #15 (permalink)
California Expatriate
Darwood's Avatar
Any reason you painted the brackets from Slee? Are you just into black?
'97 LandCruiser (Slee bits with OME418 and SOF4RH springs; Slee step sliders; African Outback full length roof rack; ARB front bumper, Hella 4000s; Kaymar rear bumper, tire carrier, jerry can carrier; BFG AT 315/75/16 on OEM steelies)
'09 WRX STi
Darwood is offline   Reply With Quote
Old 02-11-08, 10:26 AM   #16 (permalink)
SF80's Avatar
They were cheaper than the optima yellow top by @ $20 each (in the same group size.) These are great batteries since they are "dual-mode" deep cycles -- they are both good at cranking and deep cycle.
Actually the closeness of the accessory posts to the main posts gets in the way and limits the orientation of the main post terminals. It took me a little while to get the wires in the position I wanted.
Brian
'08 BMW 135
Old 02-11-08, 10:28 AM   #17 (permalink)
SF80's Avatar
The Slee brackets come in the anti-corrosion yellow. I just wanted to make it a neater-looking install by matching the black in the engine bay, no real "functional" purpose.
Brian
'08 BMW 135
Old 02-11-08, 01:01 PM   #18 (permalink)
Pinoy 4WD Journey
4x4CPOSEADOG's Avatar
TLCA# I'll get one soon
Just like Romer said, it is an excellent write up. Totally cool. Which Battery Isolator/Combiner did you use? I did not see that on the list. Also, how come the ground wire has the fuse but not the positive wire?
Can't wait to install mine too and this thread will be useful in installing mine, specially the clear pictures. Thanks for a very detailed write up.
Noel
97 LX450 unlock, IH8MUD decals, CDL/Pin7, HIRs, Cup Holder, 100 pads, GS LEDs, OEM grab bar, sidemarkers, ARB bar/XD9000, PIAA 520, 295/75R16 NTG, Kaymar Deluxe/tire carrier, OME850J/863, Slee speedo gear/SS brakelines/caster plates, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter, auto up and H2O temp mods. Need install: OEM subtank, BIC 95300B dual batt, blue fan clutch, OEM rear locker...
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 02-11-08, 01:20 PM   #19 (permalink)
The quick brown fox .....
Beowulf's Avatar
"The parts:
* Group 31 Optima Marine grade batteries (amazon.com)
* FJ80 PS Battery tray kit from CDan
* Hellroaring isolator/combiner
* 150 amp ground fuse block (from mike at hellroaring)
* Slee washer bottle relocation kit
Title of the thread is "Hellroaring Dual Battery Install". 3rd item in the list. Post 3 has discussion and pictures of the Hellroaring isolator and where he installed it.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 02-11-08, 01:34 PM   #20 (permalink)
SF80's Avatar
Specifically it was the Hellroaring BIC-95300B
The product is great, and Mike @ Hellroaring is very helpful, but his site is a little difficult to navigate.
The fuse on the ground is intended to avoid "catastrophic" failures, instead of trying to fuse the positive load side.
Brian
'08 BMW 135
Old 02-11-08, 01:36 PM   #21 (permalink)
Pinoy 4WD Journey
B, what I'm looking for is the Battery Isolator/Combiner (BIC) model number. I know about the thread title but I'm specifically looking for the BIC model number i.e BIC 75300, BIC 95300B etc.. etc... that he installed .
Noel
Old 02-11-08, 01:41 PM   #22 (permalink)
Beowulf's Avatar
OK, SF80 posted the model number. I have the same BIC and am quite happy with it. Works as designed. Competitive price. Good instructions. Highly recommended.
-B-
Old 02-11-08, 01:56 PM   #23 (permalink)
Pinoy 4WD Journey
Thanks SF80 and Beowulf, that is the model number I'm expecting to receive on the mail this week and this write up will tremendously help me in the install process .
Noel
Old 02-11-08, 02:31 PM   #24 (permalink)
SF80's Avatar
Good luck on the install! As stated above, beware of the tight space on the isolator.
This pic shows how much of the lugs i had to grind down (use the zoom-in feature in the upper-right):
Picasa Web Albums - Brian - TLC Dual Batt...
Even after you get them ground down, the retaining nuts have to be pretty tight to avoid having the cables rotating and touching. I might even re-shrink tube the two ends on the isolator all the way down the lug and trim with a knife where it attaches to the isolator, just to avoid arcing.
Brian
'08 BMW 135
Old 02-11-08, 02:54 PM   #25 (permalink)
Beowulf's Avatar
If you use the lugs that come in the Hellroaring kit then you don't have to worry about the lugs. They fit fine (tight, but fine) and you won't need to grind or do extra shrink-wrapping.
Nice install SF80 and good documentation.
-B-
Old 02-12-08, 12:41 AM   #26 (permalink)
NorCalDoug's Avatar
TLCA# yes, I have one
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
NorCalDoug is offline   Reply With Quote
Old 02-12-08, 08:10 AM   #27 (permalink)
Greetings:
Nice write-up and install. Is your 150 amp fuse on your negative (ground)? If so, why? On my dual battery install I have it on the positive very close to the starting battery before the long run to the aux. battery.
Thanks,
Steve
94'
185,000
Steve
94 FZJ80, Nitto Terra Grapplers 295's, Hanna sliders, CDL Switch, Aussie Locker, Lifted Spare, Slee front bumper, M12000 with incabin controls, Slee skid plate, OME springs/shocks, A-piller mounted aux temp gauge, Surepower battery system, Aux condensor fan, 1500 watt inverter, hand throttle, CB.
stlcruiser is offline   Reply With Quote
Old 02-12-08, 11:11 AM   #28 (permalink)
SF80's Avatar
Hi Steve, see post #20. Basically, this is the reccomendation from the isolator manufacturer to have it close to either the pos or neg posts of the aux battery.
Brian
'08 BMW 135
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/204486-hellroaring-dual-battery-install.html
Posted By For Type Date
mbraly's landcruiser Bookmarks on Delicious This thread Refback 01-03-09 05:26 AM
unwiredadventures's LandCruiser Bookmarks on Delicious This thread Refback 09-16-08 11:18 PM
calester's ih8mud Bookmarks on Delicious This thread Refback 08-30-08 05:01 PM
calester's dualbattery Bookmarks on Delicious This thread Refback 08-21-08 10:52 PM
calester's Bookmarks on Delicious This thread Refback 08-21-08 10:50 PM
San Francisco Overlander | Google Groups This thread Refback 06-16-08 01:35 AM
Slee Water Bottle relocation kit Installation - San Francisco Overlander | Google Groups This thread Refback 06-15-08 11:25 AM
Slee Water Bottle relocation kit Installation - San Francisco Overlander | Google Groups This thread Refback 06-15-08 10:54 AM
San Francisco Overlander | Google Groups This thread Refback 05-20-08 08:39 AM
Alternator for 80 series - San Francisco Overlander | Google Groups This thread Refback 05-18-08 07:21 AM
