- Joined
- Jan 6, 2012
- Threads
- 341
- Messages
- 10,937
35" krawlers
They are bfg km2 35.12.50.17 on American Racing ATX rims from Discount tires...What size wheels are those man? 16"? looks good
Hi,
I am interested to buy 35 tires.
Is it more comfort to ride than 33 tires?
If you use 35 tires, please show me the pictures.
Thank you.
Can you show some pix of the bed, did you widen it???No build thread. Took a 66 FJ45 that was incomplete in boxes and mixed in parts from a 40, a 55, and a 60.
Used this forum as a guide for each part.
My work is not finely finished.
If there’s something in particular you wanted to see I could post it if not redundant to better posts.
66 FJ66 cab and frame sandblasted,
Triple epoxy primed
monstaliner to floor/firewall both sides
New windshield
New corner windows
New rear slider
78 FJ40
Wiring harness, refitted/deleted smog
Windshield frame with wipers on bottom
New Racer wiper motor
Rebuilt Transmission/Transfer&ebrake
78 firewall grafted in on drivers side for Racer brake booster
81 FJ60
2F engine/new OEMpower steering-pump 50amp alternator -
complete rebuild/head- shaved .030. Valve grind
de-smog w JimC idler
Intake under carb built up alum weld
Modern double circuit power brakes
New clutch system
New aluminum radiator / hoses
Weep hole in head tapped & plugged
Exhaust stainless flex joints/resonator
78 small cap electronic dizzy
Oil pressure warning light
Steering
Column-
fj55 inner w u joint,78 fj40outer tube
Intermediate shaft to box from inside fj60 column (is collapsible)
Fj60 power steering box & Pittman
Steering column inset towards cluster 1”
FJ60 axles complete rebuild w ARB Air lockers 4:10 ratio
Kept rear ebrake, handbrake behind seat
Alcan 4” lift 55 Springs, 1” added to shackle ends, 500 lb extra load custom
New greasable pins/longer shackles
New custom driveshafts
Original seat raised 2”
Tranny shifter altered to clear safe
Odyssey battery
Roll bar to frame/Gr 8 1/2” bolts
Trailer hitch 7way/4way plugs
LED taillights
Racer LED headlights
Monstaliner inner roof
New 3way Humvee seatbelts
Racer Fuji carb
Mitsubishi dropside mini truckbed
Subframe made to tie-into frame and roll bar
4Plus side boards
6 degree pinion angle shims
Schwab measured 3.4 degree positive caster
Bed came off miniature Mitsubishi truck.Can you show some pix of the bed, did you widen it???
View attachment 1750709 View attachment 1750710
Aussies have figured out, with their traybacks, what makes best bed. Each side folds down or is instantly removable. Makes loading feed bags,etc much easier. Whitey had done one, so I kept my eye out for one. The 66 Fj45 I did didn’t have a bed so it was an easy choice.
Thanks, great pix, love the concept
I looked up the dimensions and they came back at 49" wide, wonder if I could get 2 and make one about 60" wide.... that would be perfect
35s don't typically interfere with leaf springs but will hit the tie rod along the frame if you still have the old manual steering setup. I think leaf spring interference occurs once you get into the 38" tire territory. I would probably do 3.25" backspacing just to make sure it clears the tie rods ends.When fitting 35 x12.5 tires, is the typical 3.5" backspaced wheel (to clear the rod ends) enough or are spacers needed to keep the larger tires out of the leaf springs and such?
OP hasn't been here since 2011.Btw to the OP.. if you go bigger you are most likely going to need to cut and roll your rear fender lip...some of the images here will attest to that as well. Maybe something you knew already but if not. Well give loosechange a fist bump yeah? J/k
Stay with 35s!Prior to restoration. May stay with 35s because they are very comfortable on road and capable off-road! Let me know what you think!
What’s wrong with the rear shackles?
