For starters, it sounds like you need to do a full tune-up, just to know where you stand. I don't know how steep these roads are, but you should be able to pull more than 25mph on all but the steepest paved CA roads.
I've seen this advice several places on 'mud. The manual specifically says to avoid high RPMs in 1st and 2nd gears for extended periods. I believe this is because the torque converter won't lock-up and could be damaged due to heat...?
Just wait till you start climbing up a 7% grade, on a two lane road above 8000 feet, pulling a full camp trailer. That's the perfect time to explain to your wife why you need to spend all that money on a shiny new Sequoia.
How about anything to do with the exhaust to help get more power? So far the I have done the other things mentioned except for the timing advance. That’s what’s up next for me.
First things first young man...find the closest gerbil race track...break into any one of the dozen 100 series there...after almost passing out from Old Spice...open the glove box, behind the vanilla bean lotion, in front of the Pottery Barn gift card, against the grey-out hair remover, you will find the Mazda Miata faux leather gloves. Grab one.
I put a 2.5" exhaust to replace the 2" exhaust. This definitely gave me more horsepower because I paid for it and don't want to believe I wasted money.
Moreover, if someone questions my horsepower I go into 100 series owner theatrics mode and slap them with a Mazda Miata faux leather driving glove I stole from a 100 series owner in Scottsdale and challenge them to a duel for questioning the additional 20hp I've espoused. Luckily no one has died but I've used the hell out of that glove.
Zona
Define "extended periods", is that hours, days? The torque converter unlocks when the throttle input is is significant, so is not going to be locked when climbing grades. With a delicate rig like your explaining, probably best to never travel in sand, likely to be in 1st and 2nd gears with big throttle input for "extended periods". Better to upgrade to that new Sequoia?
In no "abuse" condition have I ever noted transmission temp that I would be concerned about. The 1fz makes the most power at 4000ish rpm, when power is needed, use the shifter to find the proper gear to get there, or ride in the slow lane.
Define "extended periods" ... With a delicate rig like your explaining,
