Please help for a newbie.
California
Hey everybody.
I have a simple question that I am sure I will get many complicated answers for.
* please don’t tell me to search for it, I already have and I am more confused than ever.
If you guys know of any other mods I can do that doesn’t include swapping out the engine to get more power out of the engine. I just bought a 97 fzj80 Non-locked, 180k miles and one previous ower california car. I want to take it to the mountains for ski season but I found out that my baby stinks on the hills. I have a very small budget so engine swap is out and pretty much an SC too. If I were to save, which one would be best to do new engine or SC? I know I am going to catch some heat for this, but I am not a fan of diesel.
Please be kind and thank you in advance.
It is just the nature of the 80 with 1FZ and there is not much you can do about it without force induction or engine swap. It may be slow but rest assure it will get you there. ;)
Push the ETC button...:meh:
^^^^x2. I realize I see more of the world as designed by TEQ. I call it windshield therapy. These days so many are obsessed with speed and power. The journey is where it is at for me. Love it that it has no "media" ports. Taking the journey each time has helped my boys tremendously. They have a good love for this world. Take it in.
Easy on the wallet too than a swap. The 1fz-fe is a cool motor. I just rebuilt mine at 245k. Cylinder bores still had the factory hone marks!!!! Not much out there that is durable.
Plugs, wires, fuel filter, fuel pump sock, advance timing.
Slow down and enjoy the ride man. Life is short.
And since nobody else said it... find someone with a 3FE 80 and drive it for a little while. The 1FZ-FE will seem like a race car comparatively! (It actually doesn’t but people think that it would...)
To think of it mine is slow with armor and 33" tires cruising in Colorado mountain. If it is factory spec it shouldn't be that bad. Like other member mention go ahead and do all the preventive maintenance and it should run great.
Just to be clear. I have absolutely no problem with the truck or the engine. It’s just driving up single lane mountain roads with traffic behind me and only being able to muster it up to 25mph. It’s both dangerous and uncomfortable. I am all for taking it slow and enjoying the ride. I wouldn’t have gotten a LC if my intention was getting there fast.
Does it have larger tires? Gearing would help.
Otherwise a tune up should help a little.
Buy or just drive a 91 or 92 with the 3FE then report back with your comparison about how your 97 FZJ80 sticks on hills. BTW the 3FE has about 30% less hp. I say "Enjoy the scenery".
They say the 80 is the best all around car that has ever been made. It's really good at a lot of things which means it's marginal in other areas. Hammering up mountains at 90 miles per hour is not among it's attributes. It will get you where you are going and back though.
Patience is a virtue....
What RPMs are you seeing climbing hills? If you're maxing out at 25 mph on a reasonable road somethings probably wrong (assuming you're close to stock and not carrying lead bricks in the back)
As of now all I have done as a mod is add an EMU 2.5 lift with the stock tires still on it. I am saving up for 33s. What could be wrong if 25mph is all I am getting?
How about anything to do with the exhaust to help get more power? So far the I have done the other things mentioned except for the timing advance. That’s what’s up next for me.
@Sean80- Where, exactly in CA and what elevations are you traveling single lane roads that are so steep you can only attain 25mph with stock tires?
Fantastic question and I have the same set up as you. You'll love the motor when you learn to drive it.
I was just speaking to @Tools R Us this morning about how it took me a couple months to figure out how to drive the rig when I first purchased it.
The answer is very simple and you'll get the hang of it:
1. When you sense it's losing power hit the overdrive button, this will shut it off, this will give it a little boost, and
2. When that starts to lose power due to the high hill you drop it into 2nd gear, the rpms will jump to around 4k, don't go past 4600 rpms
3. When it begins to level off and you're picking up speed put it back into Drive and then hit the overdrive button again to turn it on.
between 3800 and 4400 is when you get the most rpm's out of the cruiiser so don't worry about it getting loud and sounding really angry. You'll get up to 60-65 by dropping it into 2nd. I drive my rig up the mountains this way on the freeway with my family loaded with luggage, gear, coolers, etc.
Practice it and you'll love the engine.
Zona
Zona
whole nother level..Zona!
For starters, it sounds like you need to do a full tune-up, just to know where you stand. I don't know how steep these roads are, but you should be able to pull more than 25mph on all but the steepest paved CA roads.
I've seen this advice several places on 'mud. The manual specifically says to avoid high RPMs in 1st and 2nd gears for extended periods. I believe this is because the torque converter won't lock-up and could be damaged due to heat...?
Zona
Awesome best response yet. Thanks.
