Please help for a newbie.
I drive all over Southern California, some of the roads in the high desert are a problem for the old girl. I also drove across country in it and I had a really hard time in the Rockies. I would like to go back to the Rockies but i am hesitant with the lack of power. For example when I went thru Vail it maxed out at 25 mph and I had to drive on the shoulder.
Order some Holly and Moroso window stickers from Summit..... I’ve heard they are good for 5-10h.p........ EACH!:flipoff2:
Drive as @zona described. I drive all over California: Big Bear, Joshua Tree, Borrego, Mammoth, Bridgeport, Truckee, Susanville, Paradise, Shasta... and my truck is much heavier than stock. Get used to down shifting and watching the RPMs. I still can hold 65ish going over the Grapevine and 55-60 coming into Bridgeport from the south on I395 while loaded down. Holding 55mph into Big Bear has never been a problem for me.
Just make sure your oil and cooling systems are up to spec and you’ll be good.
Yeah, sounds like you need to baseline before you go any further. I took my Cruiser from Phoenix to Flagstaff and up through Denver and had no problem maintaining 45-50mph up long passes with my dog of a 3FE. You ought to be doing way better than 25mph up hills unless the video below is your idea of a moderate hill...
Fantastic question and I have the same set up as you. You'll love the motor when you learn to drive it.
I was just speaking to @Tools R Us this morning about how it took me a couple months to figure out how to drive the rig when I first purchased it.
The answer is very simple and you'll get the hang of it:
1. When you sense it's losing power hit the overdrive button, this will shut it off, this will give it a little boost, and
2. When that starts to lose power due to the high hill you drop it into 2nd gear, the rpms will jump to around 4k, don't go past 4600 rpms
3. When it begins to level off and you're picking up speed put it back into Drive and then hit the overdrive button again to turn it on.
between 3800 and 4400 is when you get the most rpm's out of the cruiiser so don't worry about it getting loud and sounding really angry. You'll get up to 60-65 by dropping it into 2nd. I drive my rig up the mountains this way on the freeway with my family loaded with luggage, gear, coolers, etc.
Practice it and you'll love the engine.
Zona
I have to agree. My ‘97 is the first automatic I’ve ever owned. So it’s taken a couple years to figure out how to drive it.
:lol:
Plus it has a lot of fancy buttons and features that I had to figure out.
First thing is, turn off the overdrive when you start climbing. I keep “power mode” on all the time. Don’t be afraid to shift down into 2nd. I can pretty much go as fast as I feel like. I’m on 35s, stock gearing.
Check your exhaust system. Maybe your cats are beginning to disintegrate?
Cut a hole in the floor and put your feet on the ground like Fred Flintstone. You will probably build speed faster than with the engine in an 80 series. The upside is that it does climb like a billy goat when off-roading!
:lol:
I think we lost him.
Awesome best response yet. Thanks.
Have you done any kind of tuneup or anything on it at all? You never really addressed that question.
You shouldn't really be having any problems climbing hills...
I just drove mine over the Continental Divide on I80 going East... Power wasn't something i felt it was truly lacking. Left the cruise control on, running 70-75mph. It only jumped out of overdrive two or three times. If you're really maxing out at 25mph, something is drastically wrong.
Geez, wish I could do 65 mph...sometimes.
The Pig is slow, but the Earth is patient.
There is more to life than simply increasing its speed.
WHOA!
