Good info buddy. I guess you would pick a solenoid equal to or greater than your secondary battery rating? Or a combination of primary plus secondary? I am an electric moran.
I'm beginning to wonder if battery controllers give a false sense of security?
I think I would question the statement that the indicators only show alternator voltage. If voltage were a constant 14.1 whenever the alt was running then lights wouldn't dim when the fan was turned to high nor would the voltage sensing switches isolate to the primary battery until above 13.7. The indicators show the voltage of the system. There will always be some drop under load. True, that 95% of the time, a healthy system will achieve alternator voltage shortly after start and remain there, making constant monitoring mostly irrelevant, especially with the factory gauge. But we don't monitor for normal, we monitor for failure.
If you take the LCD box of any dual battery management system and touch the (+) to (+) and (-) to (-) on your running vehicle with only one battery, it's going to light up both sides of the box. Correct?
I agree with you if running a stock alternator. My lights don't dim under any conditions with my new alternator.
The statement from another post about the LED's is only accurate if you wire the display panel to only come on with the vehicle running. The way I did it, I can monitor both batteries separately when the truck is off and the key is not in the ignition, this way, when camping and actually using the aux battery I can monitor it's state of charge. With the Iron Man DBS ($275) the alternator will only charge the main battery when the vehicle first starts and you can also see this on the display. Once it detects a suitable charge level for the starting battery, it combines the batteries and charges both. If I shut my truck off at camp it automatically disengages the main battery from the aux, and I am guaranteed to never forget to flip a switch and drain my starting battery. It was worth the extra money to me to have a solution that I didn't have to remember to use.
No. Only when the batteries have been combined. If the batteries have not been combined you get the accurate reading off of each battery.
Not true. Try it. You don't even need a second battery to get a two battery reading when the truck is running. If you shut the truck off, it will show one.
Christo, I have to stop by this week anyway. Do you have that new LED display ready?
I am not talking IBS I am talking Ironman and you are incorrect. The LED display wires to EACH battery independently, so you will only get a reading if there is a second battery present.
If the truck is running and has been more than 10 seconds and the primary battery has a sufficient charge, then you will read alternator voltage for both batteries. If the truck is turned off, the batteries automatically disconnect (via stepper motor controlled solenoid, not a relay which means you can manually override either way even if the stepper motor goes out.) and you will read real battery voltage independently.
I am glad your system works for you, I went a slightly more expensive approach which was worth it to me based on what I wanted from my DBS.
Christo, is this the ACR you were using? Using their switch looks like it would be easy to kill chatter by hitting the combine button.
http://www.bluesea.com/products/7622/ML-ACR_Automatic_Charging_Relay_with_Manual_Control_-_12V_DC_500A
http://assets.bluesea.com/files/resources/instructions/990180180.pdf
