I'm about to embark on the finally outfitting my 04 LC with a true dual battery setup. This something I've put off for a very long time. However I'm on the verge of adding several electrical accessories to my LC and need to first complete the dual battery installation as a foundation. I've done countless searches here and on other sites. I've looked at countless other dual battery setups. Some have different accessories connected to different batteries within the system.
Here is what I have planned for dual batteries. I've already purchased and received the upgraded main battery tray ($70) from SHAGGY101. As for the secondary battery tray I planned on purchasing the 2nd Battery Tray ($79) from Slee.
The SHAGGY101 main tray is designed specifically for the Sears Platinum Group 31 Marine battery. The Slee 2nd battery tray is designed for a Optima Group 34 battery. I measured the Sears Platinum Group 34 Marine battery. It's basically the same dimensions as the Optima (hence both Group 34) and will fit the Slee tray.
Dual battery selection:
Sears DieHard Platinum PM-1 Group 31M - Main Battery ($279.99)
Sears DieHard Platinum PM-2 Group 34M - Aux Battery ($219.99)
At this point I will have two new Sears batteries installed in their respective trays. The main battery will be hooked up to the OEM wiring harness and the 2nd battery will not be connected yet.
Next I will be purchasing a IBS Dual Battery Management System ($466) which is currently on group buy here on MUD through Sierra Expeditions.
Once all said and done I will have a dual battery system installed and connected as this diagram.
At this point I'm in the hole around $1100 and ready to start connecting accessories to my new dual battery system. Here is a list of the accessories I'm envisioning.
1. Superwinch 12.5 SR
2. Quick disconnect jumper cable on front ARB bumper
3. Quick disconnect jumper cable on rear Slee bumper (future)
4. IPF fog lights in front ARB bumper
5. (2) Hella Rallye 4000 100w halogen driving lights on font ARB bumper
6. ARB 47L Fridge mounted in the rear passenger seat area
7. Blue Sea 12 position fuse block inside the vehicle either center console or rear area
8. Xantrex PROwatt SW 1000watt DC to AC inverter located in the rear cabin (part of drawer system)
9. Cobra 29 LX LCD CB Radio (mounted on center console)
10. 2m HAM radio (future, mounted on center console)
So, let's start with winch. I've seen some people recommend that it be connected to the main battery, some to the aux battery. One would think logically it would go to the starter battery, also where the main feed is from the alternator. Some argue you should run it off the aux battery in case it damages the main battery. Keep in mind the IBS system has the ability to combine both batteries together in parallel for example when winching.
Same story for the jumper cables, main or aux?
The rest I think I have a good idea, they should all be connected to the aux battery. The fog and driving lights, I would like them to be able to run with the engine not running and without fear of killing the main battery. The fridge and internal accessories off the fuse block all connected to the aux battery. I want these to have direct power at all times, regardless if the ignition is on or engine running. Any reason any of these should not have direct power at all times and be switched via the ignition?
What am I missing? Thoughts?
