This is from my rear seat the only good vinyl 10/78 Fj55
still has the working electric buzzer and is the kind that the seatbelt comes through the "sitting" part of the seat; a real PIA when it drops down beneath the seat
got 4 daughters and a wife.....:whoops:This is not a seat cover....
This is the material used to recover the seat.
Toyota calls them, "Seat Cushion Cover Assembly" or "Seat Back Cover Assembly". Just depends on if it's for the top or bottom![]()
And from initial and continuing posts in this thread it would appear that nomenclature used for one thing by someone, does not mean the same thing to someone else....
If I am perpetuating confusion on this issue, I am sorry, and it was not my intention. I have spoken with Shane about this specific project many times and was under the impression that he was not making a slip-fit over your existing material and tie in place seat cover, but rather, the fabric that you would need to remove from your existing seat frame and install over the foam and spring assembly in the seat, and fasten in place with hog rings, etc, just like the factory material.
I've got a pretty decent original 78 front bench in my 71...is the same material and physical appearance as the Kansas 55/Dusty's image. All other pigs I own or have pilfered from have had the same "cross hatched Dusty vinyl"........the basket weave appears to be an anomaly![]()
Please post several pics, years and vin
Thanks Dusty!
Can you also post a pic of the front seat belts and where they come into the seat?
Best,
Shane
