LC_Hamma
The Anti-Leafer
- Thread starter
- #321
Rear Coil Stabilizer Plates:
Thanks Stu! I'll see what else I have in the parts stash I won't be needing. I'll send 'em on when Marshall comes to pick up his stuff next Sunday.
Realizing how much different the TJ rear suspension is set up from an LC, with the large upward bow in the frame over the rear axle vs. a flat frame over the rear axle in the LC, I knew I'd be stuck with small height coils. So, in order to achieve max flex, I had to fab up 4 coil stabilizer plates to hold the coils in the buckets, top & bottom. I'll be using stock height TJ coils, not the one's in the pic
Holy cow, Chuck! I didn't realize this was your beast! What a cool project! I'll be drooling often. Thanks for the piggy hood, man!
Stu
"Everything lined up"
good one! You're TOO kind ;p Can't wait to wheel with you & your group of
was to just cut off more sheet metal & align the panel w/ the transom. I felt this was a better & cleaner look:
Just gotta run some 1/8" X 3/4" around the base to the end of the floor. I added a running light too:
