PIG + Chebby Avalanche Trim =?
blast from the past- good bumpage!
I cut off the upper bar surround on the roof rack & remade my hi-lift mount. I also made my hydroboost hoses, new clutch master & slave, & added all fluids. Not getting fire so I'm in the process of tracking down that issue. Not sure I want to get this rewired as the harness looks good & is not hacked by the PO too bad.
PO? did your pig take a vacation from you? Welcome back!
Not satisfied with the angle of the old hydro ram mount on the axle housing, I should have fabbed it up like this from the beginning. I'll finish boxing the outsides next. I have a removable mount designed for the ram on the opposite end.
Steering & all associated parts are finished :p Last item to fab is I need to add braces to the front 4 link mount (outboard of the frame) as it takes the load of the front roll cage as well as forces from the axle.
Whoa!!! Are we going to get to see this thing in daylight soon?
@LC_Hamma, do you have a picture or two around the backside of the door opening? I was curious how you tied it in when you removed the rear door.
The rear door is not removed, just about everything behind it is :D
