Overheating with AC on
Nor Cal
My 100 series is overheating when I have the AC on only. It’s not super hot but the trans temp and coolant gets to around 205-210 going up the mountain to my house. I noticed today if I turn off the AC when I do go up the highest it would reach was 193 and the trans didn’t go over 170 which seemed more normal to me.
I just replaced the fan clutch , new fluid, new thermostat, and my radiator is only a couple years old denso unit.
Is there anything anyone can suggest I check next based off my symptoms only being a problem with AC on? & no I don’t want to drive home without it on 107-112 degree days.
Thanks!
Heater core? Mine was leaking from old/cracked hoses running into/out of the front heater core. Core, itself, was fine…but bad hoses/core could be your issue.
Easy to bypass the heater cores. Someone makes a kit. You could bypass it and see if it solves the issue.
b004a855-397f-4e54-860c-e33ad263de17-jumbo1x1_L.V.HEATCARSAFETYPkg.transfer.transfer_frame_1685.webp
Hello MACKSDAD,
Here's a couple of other things to consider.
Radiator Cap.
If it's old, replace it with an OEM Toyota / Lexus one.
Are you using Toyota Red or Pink Coolant?
If not, I believe there's only 1 aftermarket equivalent that's also Red.
When's the last time you had your Timing Belt / Water Pump replaced?
What year is your LC / LX?
Early (1998 to 2002 I believe...) has an Auxiliary Fan.
Late (2003 to 2007) does not.
One of the threads below discusses this.
Here's 2 threads to check out.
Good luck.
Tom
Could be this but not experiencing any symptoms typically involved with that but mine looks original so that’s a helpful start!
Hello MACKSDAD,
Radiator Cap.
Good luck.
Tom
I have a 2001 . I think I reused my original OEM cap when I changed the radiator. Not sure if they go bad? This is on my list to do forsure.
Timing belt was done 60k ago along with water pump. I was going to change it when I did my fan clutch bracket but I decided not to because it looked in perfect condition still.
I’m using zerex red coolant mixed with some napa red coolant. (Was what I had laying in garage) does the Toyota red really work that much better?
Radiator caps can go bad.
I'd absolutely replace it.
Yours should have an auxiliary fan.
I believe it should come on when the A/C is turned on, and also when your engine reaches a certain temperature.
I'd make sure it's coming on.
If it's not coming on, could be either the switch or the fan motor.
Good luck.
Tom
  • Like
Reactions: GTV
Bump. Replaced radiator cap. No difference. Aux fan seems to be working . Trans temps were around 220 today going uphill in 90 degreee heat. AC on.
Trans fluid looks clean and at correct level. Brake fluid is a little high it looks like which I saw somewhere someone say that could cause overheat. Maybe it was on @2001LC other thread.
The trans and water temps are almost going up at the same time. But the meter on the dash stays right in the middle the whole time. What temp would dictate the needle going up higher than usual?
Thanks
Thanks
Coolant is not circulating effectively around causing the engine coolant temperature to go up. Could be the thermostat which is the gatekeeper to allow the coolant to flow around. Could be the water pump to push the coolant all the way around the system. The water pump is mechanically driven or spun by the viscous fan clutch connected by the drive belt spun by crankshaft through the crank pulley. Having a clear coolant is good but wouldn’t be able to tell if the radiator has a reduced flow rate (clogged partially). These are the things I would check to eventually solve the overheating.
220°F of transmission temperature is high (safe threshold is around 200°F max, if maintained through prolonged periods of time that would cause AT problems. After around 30 minutes of driving around, I would check the overflow plug in your AT pan, remove to see if there’s a little of overflowing fluid, if there’s none at all, that needs a top up.
Always best, to post year of 100 series. In your signature line. Also any mods.
All 3 Radiators, fins, must be keep clean.
Thermostat jiggle valve must be at top.
Air must be removed from system. We check it is. By removing radiator cap, when engine cold (in AM before sun up.
Cap must be working properly.
Reservoir must be working properly. It's hose must be straight and go to the bottom, and can not have any obstructions.
Best to have correct coolant, OM states for your year.
AT must have correct ATF, and be at correct level.
Fuel trims. If running lean, cylinder head temp goes up.
All best to post year of 100 series. In your signature line. Also any mods.
I just put on a new rad cap. Doesn’t seem to have air in system. Even driving slow in 55 degree weather gets the water temp up to 190 pretty quickly. Transmission only goes over 200 when I’m going uphill to go home (about 40 mph up a grade for about 15 mins) I have a new thermostat I installed with jiggle valve at 12 o clock. I do notice the smaller fan on passenger side infront of radiator only comes on if I have ac on. Is that normal ? Or shouldn’t it turn on when engine is warm? Going to check trans fluid now. Dipstick says it’s full but going to check fill plug now.
I guess there’s no fill plug on the 01 trans? I only see the drain .
Curious, what is the max that the water temp should be? I have a scan gauge and I've had the rig (2000, has bumpers and winch) less than a year.
Got the Scangauge for Christmas and was running at 188°F no matter what, everywhere, in all types of weather for a couple of months, then I did some mild offroading and since then it's been wanting to run hot.
It can be 60° and cloudy or 106° and sunny and either way, it will rise to about 204° water temp under load.
I've hosed out the radiator pretty thoroughly and coolant is full.
I’d check thermostat and fan clutch health first. 180-190 seems to be pretty average for most people.
OEM?
"seem" Very easy to determine.
Park overnight, after reaching operating temp and ~3K RPM for ~3 minutes or more. Park on level ground or better yet, with front end higher than rear. This places radiator cap at high point. Air travels to high point!
In the morning, after engine has cool down for ~8 hours. Remove rad cap, before sun-up. Coolant should be to the very top of radiator. No air whatsoever.
That is to hot ECT and ATF.
I just drove my 03LX w/323K miles from Den on I-70 west over the continental divide 252 mile, to GJ in the AM. Did not shut off engine the whole way. Running long distances at speeds of ~82 MPH where I could (75MPH speed limit). Other times crawling along for the many road construction projects. Actually pushed it very hard for a few minutes hitting 110 MPH. Climbing multi pass from 1 mile high (Denver) to 2 mile altitude (Eisenhower & Vail passes). OAT range was 64f to 74f.
ECT never over 187f, ATF temp never over 165f.
I'll note I shift a lot. You never see me brake, except emergency running the Rocky Mountains. Point, I don't baby the engine or AT, I push them to their limits.
OEM?
Normal
ATF should be at ~160F, engine idling, pull AT dipstick. It should read in HOT range. Best if at or tad above high hot notch.
Again. All 3 radiators fins must be clean.
I drove an 06LC back from GJ to Den. OAT range 91f to 69F. It ran around 194 to 200F 06 - 07 do run hotter, with their different fan blade & fan clutch. It would go to 210F with AC on, which it should not go over ~199F. I send the morning washing bugs and Moab dust from its radiators.
I am going to agree on checking the radiator, condenser, and trans fluid cooler fins. Seems to me the most likely thing that would impact the engine and transmission temperatures.
Second guess would be thermostat / water pump or maybe coolant level, but I believe that would only show up as a hot engine temp.
I wanted to offer my input. I recently replaced the radiator on my 2000 LX470 with a new Denso unit. I took my rig wheeling 3 weeks ago and I noticed on my scanguage I had crossed 200 degrees for the first time ever. Then I hit 215. Trans temp hit 200.
I was legit shocked. I came home, double checked and attempted to burp my cooling system to no air bubbles coming out.
I have been piecing together my timing belt kit and this prompted me to test my Fan Clutch. Every test passed except when the LX is at operating temp, I turn it off, I should not be able to turn my fan by hand. My fan clutch should be fully engaged. It isn’t. I can freely spin the fan, at full operating temp. My fan clutch is not working correctly at cooling. I will be doing a full timing belt replacement, fan clutch, fan bracket, and all pulleys. As soon as this is done, I will report back.
But I suspect, the fan clutch might be the culprit in your case as it was in mine.
