A while back I swapped out the coolant hoses for new ones due to the leaks and janky hodge podge of hoses used.
I hadn't really driven her much until then, so I can't say I recall her over heating before.
Today I finished installing a new thermostat and I also installed a mechanical temp gauge because the OEM one def wasn't working.
Started her up, looked like she got to temp, I dangled the mechanical temp gauge about twenty min in and boom...she's at 200+ degrees almost hitting 210.
At this point I shut her off and I have noticed as once it heats up I can't start her again until she cools down a bit.
I believe I burped the system properly, but who knows...
You guys have any further suggestions?
Thanks in advanced.
Synopsis
Make sure you burp your system. And it may take a couple tries.
200+ is normal temp.
A carburetor fan is your friend, don't remove it.
Thanks in advanced.
Synopsis
