- Thread starter
- #221
Got the side cover gasket installed
broth9640 said:Dan I highly doubt I will beat you to the road. What's holding you up? Still waiting on those precups? My build seems to be going at light speed compared to this time last year when I was deep into body work. Now it's all clean parts and I can see the finish line getting closer. My hope is to be on the road by August.
DanS HJ-45 said:Yep. Precups arrive, then a day or two at the machine shop, followed by a day to put it back together. That's the plan at least.
....so you're planning to have it ready for the 40s only run then??.
Dan
broth9640 said:40's only run? When and where is that? I guess I will have to scratch it sometime![]()
Crank shaft pulley installed. It called for over 250 foot lbs of torque! So I tightened it as much as possible and staked the nut. Once it's in the vehicle I will try a little body weight with the breaker bar to make sure it's as snug as possible .
