- Thread starter
- #681
Hey Gents (DanS HJ-45 & broth9640),Last Pic. I still need to finish up the passenger side rear tie in, but I have to head off to my real job!Hopefully I can get it done on Monday and have the frame , axles, and springs sent off to the sand blaster.
I am about to tie-in my Metaltech cage to my rig and how do you guys liking the frame tie-in with the Poly Bushings? Was it worth the extra fab and install and see any issues arise? I am debating what to do... Weld them straight to the frame or basically follow what both of you did. Any advice would be great. Thank you.
Christian
That is great to hear. I am definitely leaning more towards using the bushings for the tie-ins. Now for the bolts that ties in the bushings to the frame, did you use a grade 8 steel bolts? Thanks Dan.I have liked it. Of course, we haven't had to remove them for any reason, but the cage is pretty unnoticeable. It doesn't get in the way of anything, doesn't vibrate a lot, and it just sits there being safe.
The only thing I did that I didn't like is that I put the cage as far to the outside as I could, to give as much room for the leg on the clutch pedal as possible--which means that I can't crank the windows up and down with the door closed. It clears the doors, but the door crank hits the cage, so I have to open the door slightly to roll the window up or down. Which is a minor inconvenience, but no big deal.
Dan
