Oil pan install question
Durango, CO
Website
www.kindel.com
Quick newbie question for replacing the oil pan:
Do I put the liquid sealant (FIPG) on the oil pan side of the gasket or the block side or both?
I have read all the tech articles and old forum posts and the FSM but given i've never done this before it's not clear to me.
The liquid sealer is only applied at the corners of the block (flat part) where the gasket transitions from flat to the curve. It is also applied to both sides of the end plate gasket prior to installing the end plate. There is no liquid sealant between the gasket and the pan. Again, it is only applied in 4 places between the gasket and the block.
PabloCruise said:
I ran a bead of Ultra-Back all the around - both sides...
and? has it held up? how long ago did you do it? just curious. I heard this is tough to do as it can get soiled and pushed around when trying to put the pan back in place making a real mess?
Apply a heavy dose of sealant in the corners if it is a four piece gasket.
Apply a light layer of sealant on both sides of the entire gasket. This is largely to make it easier to remove if you need to at a later date. The sealant keeps the cork gasket from gluing itself to the metal surfaces over the years. The cork actually gets pressed hard enough into the prse of the metal to bond to it with an iron grip. :(
Tighten the pan gently at first. Not enough to make the gasket bulge. After it sets for a couple of hours tighten it more. Just enough to get a small bulge of the gasket at each bolt. If you tighten it completely before the sealant sets up some it will tend to squish the gasket out. Especially at the corssovers at the end of the pan.
It is always worth checking the gasket after a couple of weeks and again after a couple to six moinths or so. The bolts tend to loosen up. So do side cover bolts. I;ve seen many rigs come in with owners who think that they need new pan gaskets or even pans, when all they need os for the bolts to be tightened.
Mark...
Trust me, I know what happens in that case. That is how my gasket was when I tried to remove it. What a bitch!
Thanks.
Mark...
I installed per the book and it has been ten years and the gasket has not leaked. I'm just curious, you mentioned a four piece gasket. What years use a four piece gasket. The gasket on my 78 is one piece.
4 piece gasket is an aftermarket unit. And of lower quality. One piece gaskets are bettah..
BTW, I never use silicone on a cork gasket. It does nto allow them to swell like they are designed to.
Bout the only thing I like to use on cork gaskets is permatex aircraft sealant.
I use it on paper gaskets too.
For valve covers only use it on one side, makes it easier to adjust the valves (something I never do either...)
Fine. Although it was my second attempt at it w/ new pain, so I was pretty determined to get it right...
First I chased all the bolt holes in the block, cleaned the saddles, sprayed with brake-clean.
Then I ran ultra-black on the block and pan - don't 'member which one I did first. I got the pan in place and started running the bolts in - starting at the center and working out, alternating sides. Finger tight first, wait, then a little tighter, etc.
The rig was down for a bunch of repairs, so I didn't need oil in the pan for a few days, so I waited. I drained the oil and let the bottom end drip for a few days too before pulling the pan. I primed the oil system with a drill and shaft connecting to the oil pump - spin the pump while engine is cranking over.
I got tired of re-tightening the pan bolts, so I went back and put the blue loctite on them and the front cover bolts. Seems like the bolts that go into the front main cap always loosen up a bit. I think I heard of someone wiring them up aircraft style with safety wire so they couldn't loosen...
Yay! I finally got my pan back on.
I ended up putting a light bead all the way around both sides of the gasket and a fair bit more in the corners.
I tightened the bolts using just a screw driver and used some lock-tite blue. I am assuming that this prevented me from over tightening them, but will also keep them from backing out.
I won't be putting oil back in for a while (got lots more to do still)...
Fipg
Opinions are good. But my Master Tech's swear by Toyota's FIPG sealant and they call it F:censor: ing Im-Penetrable Glue for a reason!
I'ts not cheap and is does not act cheap. FSM manual did not have FIPG back in the day, but if you take your ride to a Toyota Dealer you have FIPG on the repair.
Do not use a bead anyplace, a thin coat is better on a super clean area.
Again, This is not my opion but someone who fixes our cars for a living.
So :flipoff2: ;)
FIPG stands for Form In Place Gasket.
I would use a real socket/ratchet and extension on them....you are not going to be able to get these tight enough with a simple phillips/combination prybar/punch....;)
So :flipoff2: ;)
:flipoff2: to u too Shane. I used FIPG. Next time (never!) I'll lay it down as a thin coat instead of a bead. You got that sending unit cover for me?
:cheers:
Torque setting?
