did you have to mod the bore at all? and can run them with no spacers?Method 305 nv
Nope…just plug and play…they are run with no spacersdid you have to mod the bore at all? and can run them with no spacers?
Looking into a similar route. I also love the patagonias, plus they can be had for very cheap on marketplace.More pics, including the those long Dobinsons VT coils with no coil bow at 5.5” of lift and proper driveshaft angle/caster. Third pic is just a little BFH hammer coaxing so the inner fender is angled for no rubbing at full crank including off-road. There’s nothing but air back there so that’s about as easy as it gets.
As far as I’m concerned, this is about as perfect a ’don’t hack it up’ setup as you can build. I‘m not doing 40’s because I hate the front fender chop, and the Patagonia is the best tire out there anyway if you keep it on a narrower rim so it’s only running on the inner 8” or so of tread. Quiet, smooth, awesome traction, excellent snow tire. And cheap. There is no way I could fit a squared off 38”, I barely have more trimming than I needed for tiny 37” ko2’s.
80s were mad for 37sHow the hell does a true 36,5 look so small on that car? Everything get's so damn expensive if you follow that rabbit hole...
80s were mad for 37s![]()
It’s because Dobinsons is rating these coils for use with heavy accessory load (full bumpers, etc.). I think you’d be very hard pressed to get them to 3.5” and it’s just more coil than advertised. On my rig it was a full inch over the 4” flexy Dobinsons and I was 4.5” on that setup. I had to adjust pinion angle alignment front and rear and went to a bit longer shocks accordingly. The stability of this coil is exceptional and they ride great on a lighter rig since they are dual rate - there is no issue with the coil being too ‘heavy’.Looking into a similar route. I also love the patagonias, plus they can be had for very cheap on marketplace.
So you said 5.5" of lift, but those dobinsons are advertised as 3.5". Is that because you're light and that is an actual before and after measurement from old worn out stock springs?
About what I figured. Plan is to run the 2.5 variables and stuff tires. Same shocks as youIt’s because Dobinsons is rating these coils for use with heavy accessory load (full bumpers, etc.). I think you’d be very hard pressed to get them to 3.5” and it’s just more coil than advertised. On my rig it was a full inch over the 4” flexy Dobinsons and I was 4.5” on that setup. I had to adjust pinion angle alignment front and rear and went to a bit longer shocks accordingly. The stability of this coil is exceptional and they ride great on a lighter rig since they are dual rate - there is no issue with the coil being too ‘heavy’.
Noting I carry a 38” spare in the cargo area, tools, and spare axles so there’s some weight back there.
You ARE on mud. I did an engine rebuild about the same time you did and used a couple of your early videos of the teardown. Thanks for those.Milestar 38x17x13.50
Icon Rebound Pro 17x8.5 +0
Spidertrax 1.5" spacers
RAM mounts from eimkeith
Panhard drop from eimkeith
3.5" dobinsons VT + IMS
Might deflare it, but no issues with ripping them off...yet.
View attachment 3439758View attachment 3439759View attachment 3439760
Stick to 37x12.5 and shoot for 3.5” backspace. In a 17x9” wheel it’s -38 offset. Anything close should clear 37s with minimal work.Hey guys, I'm currently running 35's on stock wheels and a 3.5" variable Dobinsons lift. I have zero rub anywhere even under full flex. However, with my LS swap coming to completion, I'm looking at stepping up to 37's. I'm seeing reviews of set ups on here about rub at full lock, but does anyone have any input on rub at full lock while flexed out? Making big tires work on the street and on the trail are very different tasks. I have zero desire to run spacers, so any input on backspacing set ups under hard wheeling would be greatly appreciated
Pic is of me failing to get up the wall at Spring Creek from lack of power in the stock engine (intake and exhaust leaks were also plaguing me) and gearing
Similar story for me but when I moved my axle forward I had to trim my Slee Short Bus. Tire choice is also a big consideration. My 37" Maxxis Razrs measure 2+ inches taller than Ko2/ KM3 in the same size.Running 17x9” -12mm offset wheels I had to move my front axle forward 1” to prevent the fronts from running the rear inner fender at full lock. No issues now.
details here: 80 Series, moving axle forward? - https://risingsun4x4club.org/xf/threads/80-series-moving-axle-forward.27596/
