OEM Part Number List
mattressking
10 digits to freedom
Idaho
DISCLAIMER: Below is for 80-87 2F. It is still your responsibility to verify fitment. Toyota still offers a lot of parts new...please check with local dealer, partsouq, amayama for availability.
EDIT: Now 3 years later, this just looks like a blanket list...not very helpful. Use as you'd like.
Engine
17801-61010 Air Filter
12204-61010 PCV Valve
90480-18001 PCV Valve Grommet
23300-38010 Fuel Filter
19101-61240 Distributor Cap
19127-61240 Distributor Cap O-Ring
19102-43060 Distributor Rotor
15600-TD004 Oil Filter
90919-21325 Ignition Plug Wire/Spark Plug Wires
90919-01065 Spark Plugs - W14EX-U
16360-61015 Carburetor Cooling Fan - Used
77310-12100 Gas Cap
25628-61060 EGR Gasket
92112-60818 EGR J-Pipe Stud
90916-03052 Thermostat
90430-43002 Thermostat Housing Gasket
16333-61110 Thermostat Housing
91611-B0845 Thermostat Housing Bolts
00272-1LLAC-01 Toyota Red Coolant
90916-01172 Upper Radiator Hose
90466-41008 Upper Radiator Hose Clamps
99554-70185 Lower Radiator Hose
96111-10510 Lower Radiator Hose Clamps
16577-61120 Lower Radiator Hard Pipe
90916-01163 Lower Radiator Hard Pipe to Waterpump Hose
96111-10580 Lower Radiator Hard Pipe to Waterpump Hose Clamps
16261-60011 Thermostat By-Pass Hose
96112-10330 Thermostat By-Pass Hose Clamps
15777-610111 Upper Oil Cooler Hose to Thermostat Housing
99556-30300 Lower Heater Hose to Radiator Hose
96112-102500 Lower Heater Hose to Radiator Hose Clamps
90467-22004 Oil Cooler Hose Clamps
99332-11250-78 V-Belt - A/C
99343-11120-77 V-Belt - Waterpump
99343-11570-77 V-Belt - P/S
16401-41021 Radiator Cap
83420-20020 Coolant Temperature Sensor
90925-05035 Bi-Metallic Vacuum Switch Valve - EGR/Vacuum Advance
16110-61081-77 Waterpump
16721-60012 Waterpump gasket
90119-A0139 Waterpump Housing Bolts (4)
99555-30280 Oil Cooler to Oil Cooler Hard Pipe Hose
15771-61010 Lower Oil Cooler Hard Pipe
90910-05155 Lower Oil Cooler Hard Pipe to Waterpump Hose
90467-22004 Lower Oil Cooler Hard Pipe Clamps (4)
90467-24038 PCV Hose Clamp
16480-90A00 Coolant Reserve Tank
16405-61040 Coolant Reservoir Cap
17306-61021 Air Injection Rail Manifold - Used
90404-14329 Air Injection Union x6 - Used
90175-06003 Air Cleaner Wing Washer Nuts x3
17848-61020 Air Cleaner to Carburetor Gasket
90915-YZZD3 Oil Filter
11213-61011 Valve Cover Gasket
90210-13001 Valve Cover Washers x4
90176-08014 Valve Cover Nuts x4
16210-61121 Fan Clutch
16361-61020 Radiator Fan Blade
90179-06158 Nut W washer - Radiator Fan to Clutch
90480-92002 Fuel Filler Body Grommet
77213-60030 Fuel Filler to Fuel Tank Hose
96111-10630 Clamp for Fuel Filler to Fuel Tank Hose x2
17781-61010 Air Cleaner Clamp to Body
23100-61070 Fuel Pump
90923-06009 Fuel Pump Insulator
90923-05016 Fuel Pump Gasket
90119-08132 Fuel Pump Bolt w/washer
90344-53011 Tapered Plug For deleting BVSV on EVAP/EGR systems
15777-61010 Oil Cooler Piping - Upper
Body/Exterior
53132-90A01 Headlight Door, Left OEM Toyota
53131-90A01 Headlight Door, Right OEM Toyota
90160-40002 Corner Lamp Mounting Screws (8)
90160-40002 Corner Lamp Mounting Grommets (8)
90154-50001 Headlight Door Mounting Screws (8)
90189-05013 Headlight Door Mounting Grommets (8)
85212-YZZ10 Wiper Blade - Front Right
85212-YZZ10 Wiper Blade - Front Left
85220-90A02 Wiper Blade - Rear
85247-90A01 Wiper Motor Cap, Left and Right
87910-90A00 Mirror Assembly, Outer
87940-90A01 Mirror Assembly, Outer
90480-15002 Hood Prop Grommet
85330-90A06 Windshield Washer Bottle
52111-60120 Front Bumper Bar w/o Winch
52102-60010 Outer End, RIGHT
52103-60010 Outer End, LEFT
81512-90A00 Front Corner Light Lens Gasket, L/R
90080-18070 Positive Term Nut - Outer Bumper Ends - Front
90112-12041 Chrome Front bumper bolts - Top x4
90179-12058 Nuts for front bumper bolts - Top x4
91659-41222 Front Bumper Bolts - Bottom x4
94130-61200 Front Bumper Nuts - Bottom x4
91621-40816 Bolt w/washer for outer bumper end
51961-36040 Tow Hook
75860-69015 Rocker Panel Moulding, LH
75850-69015 Rocker Panel Moulding, RH
53382-90K01 Bumper Hood Front
77293-60030 Upper Deflector - Fuel Filler Seal
90159-60286 Screw W Washer - Fuel Filler
85310-22080 Rear washer motor
85325-60040 Rear washer fluid jar
90467-12008 Grill Clip
75316-90A00 Grill Nameplate
90167-40010 Screw Pan Tapping - Grill
93568-54514 Screw Tapping - Grill Nameplate
85195-95700 Cover Wiper Arm - Rear
53384-60030 Bumper Fender To Ho - x4
90541-08003 Cushion x2
85247-90A01 Cap Shield
85330-90A04 Headlamp Washer Bottle and Cap
85336-10010 Headlamp bottle bushing to motor
85361-10070 Headlamp Washer Motor Bracket
91112-40620 Headlamp Washer motor bolt
90179-06070 Headlamp washer motor nut
85310-22070 Headlamp washer motor
91651-40616 Headlamp washer bottle bolt w/washer
85330-90A06 Windshield washer bottle and cap
81270-95A09 Rear License Plate Light Assy - 24V
90541-08003 Fuel Door Rubber Bumper
53341-90A00 Hood Insulator
90467-09014 Hood Insulator clips
85160-90A07 Windshield wiper linkage
85031-30010 Washer Check Valve
69513-14010 Fuel Door Lock Cylinder Rubber Pad
69581-14010 Fuel Door Lock Cylinder Retainer
52151-60041 Rear Bumper Bar
52107-60010 Rear Bumper Plastic Corner, LH
52106-60010 Rear Bumper Plastic Corner, RH
90112-12041 Rear Carriage Bolts - Upper, Chrome
81730-14110 Marker Lamp - Right Front
81740-14110 Marker Lamp - Left Front
90189-04014 Front Marker Lamp Mounting Grommet
93219-64016 Front Marker Lamp Mounting Screw
81750-29145 Rear Side Marker Lamp, Right and Left
53630-90A01 Hood Release Cable
53510-90A01 Hood Lock Assembly
91631-40616 Bolt w Washer for Hood Latch Spring
90950-01006 Plug Hole - Above Hood Lock Assy
90119-06306 Bolt w Washer - Hood Lock Assy
69563-90A00 Rear Door Lock Pad
Drivetrain
90430-A0003 Transmission/Transfer Case Drain/Fill Gasket
12157-10010 Differential Drain/Fill Plug Gasket
90341-18021 Magnetic Drain/Fill Plug
96812-50320 Clutch Slave Hose, soft line
96991-10080 Clutch Slave Hose clip for bracket
31126-60021 Clutch Release Boot - Trans side
31470-60102 Clutch Slave Cylinder
31410-60282 Clutch Master Cylinder
33030-60450 H55F Transmission - Complete
33124-36010 Oil Pipe - Nipple
33530-60160 Shifter
33504-14050 Shift Knob
31210-60070-84 Clutch Cover
31250-36342 Disc Assembly
90363-52001-77 Throwout Bearing
90363-15004 Pilot Bearing
90311-99001 Rear Main Seal
33548-60020 Nylon Bushing
90913-01016 Flywheel Bolts
90942-A1002 Lug Nuts
Suspension
90948-03011 Shock Absorber Washer x2
90119-12088 Front Lower Shock mounting bolt w/washer x2
90948-03007 Shock Absorber Washer x4
90948-03004 Shock Absorber Washer x4
91611-61020 Rear upper and lower shock mounting bolt w/washer x4
Interior
84312-20011 Plate Horn Contact
84340-22072 Stoplamp Switch
87834-14011-03 Cover - Inner Mirror
87810-90A03 Inside Mirror
93319-15012 Inside Mirror Screws
81370-60010 Inspection Lamp
81240-20060-08 Lamp Assembly- Dome Light
81240-95A16 Lamp Assembly - Rear Dome Light
90119-08079 Seat Mounting Bolt, Driver Side
This maybe picayune, but this is an OE list of part numbers...
We should also try posting, along with the OE Toyota part #, the part numbers from known OEM like Aisin/Asco, Denso, etc., that are available aftermarket.
There are many parts websites that break down the parts by major category and smaller groups that are easy to navigate. I use "Toyotapartsoverstock" as my go to diagram website to get an idea of part numbers. However, there are many like it. MEGAZIP is also great as you can look at almost any cruiser variant (worldwide) on it if you want to investigate non-US part numbers. Now go hunting you damn lazy nerds!
Good on ya!
I like.
I'm new to this whole game and have a question. Is there a way to reference what parts were put in other Toyota vehicles? If I go to the junk yard an see a corolla it would be cool to know if I could pull a relay or switch for my cruiser.
Thanks
I love it when folks play with part numbers.
It's very fun to watch.
Like going by a car accident. ;)
Nice work OP.
Haha! I know...the only problem I have with this list is that it's specific to 85. I definitely can see people buying things and it not be right.
Great list. Please check your numbers.
90189-04069 Corner Lamp Mounting Screws (8)
these goto together..just they are backwards. I just ordered the grommets. ..nice they are available. Quieted some pieces that could not be snugged.
Thank you mattressking! This will be short cut list :beer:
Just have it connected to the interweb for people to browse...
much easier
with a cart and checkout option.
:steer:
Thanks for the find, made the adjustment. Must have flipped when writing down.
I agree, I do the same thing except I use villagetoyotaparts.com as my initial diagram
source. The only difficulty Inever run into is trying to discern what microfiche category the part I need falls under (such as ac under body electircal). I then use toyotapartsdeal.com to uncover the superceding parts number.
Use the Fiche PDFs in my sig line to research (many of those part numbers have been superseded so additional inquiries may be necessary)
Little help here folks...
I ordered a new radiator cap 16401-41021 but it is to large for my CSF2708. Can anyone verify the smaller cap part #? Am I looking for a 62 cap since this rad appears to work for both 60 and 62?
Thanks for the help...
16401-54750
62 radiators changed a bit and that is what CSF radiators are based on.
