1994 has 2 o2 sensors, side by side. Same part number for both. Pain in the arse to change.
/QUOTE]
I just swapped in 2 new sensors on my '94. Hardest part was unplugging the harnesses. 20 min job at most.
/QUOTE]
Nothing that I noticed from the butt dyno. Not sure about any mpg improvements either as I have barely gone through a tank of gas since I changed them - can't seem to get my arse out of airplanes at the moment. Will know more by the end of the month.Any improvement in drivability with the new o2 sensors in your 94'? I just got a intermittent code 25 (lean) and according to my records my o2 sensors are now 14 years old with 163k miles on them.
Left sensor? Huh?
I bought both upstream and downstream sensor from Amazon and they are made by Denso.
Interesting, so which O2 sensor does the ECU uses as an air fuel ratio sensor?The 93-94 use a different configuration than your 96. The 93-94 O2 sensors are side by side, each sensor monitors 1 bank of 3 cylinders.
Gotcha, apologies for the ignoranceBoth, as I stated each sensor provides feedback for three cylinders.
Do you know where I can get this from?You need the replacement kit for a 1994: 89465-60110
1995 1996 1997 O2 Oxygen Sensor P/NsJust adding for future reference 95-97.
Front (Before Catalytic) O2 Oxygen Sensor "Upstream" Toyota part # is 89465-69085 (Denso Part # 234-4157)
Rear (After Catalytic) O2 Oxygen Sensor "Downstream" Toyota Part # is 89465-69105 discontinued as of this posting date (Denso Part # 234-4153)
Link Below also mentions parts needed for 95-97 if you scroll through it1995 1996 1997 O2 Oxygen Sensor P/Ns
^See quoted post for numbers.
(Should make this easier to find than when I looked...)
Anyone have numbers for the associated nuts, gaskets, pigtails or any other little bits that go along with these for the 95-97s?
forum.ih8mud.com
Well there's this from @OGBeno...Link Below also mentions parts needed for 95-97 if you scroll through it
O2 sensor (what to buy?)
forum.ih8mud.com
But the -69105 is NLA; the Denso # takes care of that.1995-1997:
89465-69085
89465-69105
These will come with gaskets but will not come with any hardware. 90179-08059 x4 will net you the lock nuts for the studs. If you need new studs and can get the old ones off, 90116-08211 will work perfectly.
The thought had occurred to me. And here's another thought that occurred to me: Maybe there's someone here who might know that P/N off the top of their head, or be able to find out in two seconds flat.Bummer. Maybe there are other studs that work.![]()
