No Coolant at Block Drain
Houston, TX
I realized my new to me 1970 was running hot (200) after I installed a temp guage. Decided to do a flush ( new radiator) and when I removed the drain at the back of the block I got nothing. Poked around with a screw driver and wire. NOTHING. What do I do now. Have read where others have had this problem but have not found what the fix is . Engine runs too good to pull except for the overheating. Now I am afraid to drive it till I get this fixed. How?
The 4 F engines I've played with (F135, F145, and 2 F155s) have all been that way. I ended up taking out the drain fixture and digging my way into the water jacket with screwdrivers and coat hanger wire.
It is interesting to think that it was right above that corner that my head gasket burned through and blew. Perhaps if I'd dug it out sooner that would not have happened, and I wouldn't be meeting Degnol with his old engine in a few weeks. :D
I had the same problem.
Like IDave, I dug around in there with a long screwdriver and a coat hanger and got as much of the "stuff" I could get loose. Just keep flushing and digging.
I still worry that there's a lot more crap left in there that I will never be able to get out, but.... you can only do what you can do!
Good Luck
Rocky
try takin the temp sensor out just left and up from the drain. i did this on mine and no coolant there either..... one plugged up block thats for sure. still runs but quite hot. the guy at my rad shop said only way too get it all out is too pull the engine and hot tank the whole block. i suppose you could pull the head and try diggin it out with a coat hanger....
when I had the head off one of the engines I used a long phillips screwdriver through the water jacket holes. Spent a couple of hours digging, for all the good it ended up doing.
yah thats what i figured................ it was an option that someone told me. i honestly dont feel there is a simple solution to gettin all the crap outta a plugged up block..........
sorry for the ignorance, but what in the coolant system produces that much gunk to clog the block bad enough to consider pulling it for cleaning?
well my rad guy said it can be caused by peole puttin (ferite)???? or somethnig like that it sounded like into the system to plug leaks in the rad i believe. i might be way out to lunch by sayin this but its what he said so im just passing it on. dont flame me for it.
that stuff is just designed to clog small radi holes (which it barely does effectivly - if at all)... and yet he thinks it can coagulate to the point of blocking an engine block to the degree discused here :confused: - there must be more to it to create these clogs and I can't figure out what you guys are digging out with screw driviers and coat hangers?
I don't know what it is, either. It was the same in all of the engines, and was like clay with a gritty metallic component. I figured it was a combination of rust scale and dirt.
Antifreeze does not lose it's "antifreeze" properties in two years, but the rust inhibiting properties are gone. That's why they recommend changing your coolant every 24 months. Many places just remove your old coolant, filter it and then add more anti corrosive then sell you back your old antifreeze.
I would imagine when we acquire one of these 30-40 year old trucks that they have not had 15-20 coolant changes and many have sat a long time. So Dr. Dave I agree with your diagnosis or your histi-pathology forensic report;)
Ed
You know, good question. When I was a kid only distilled water was used in radiators and batteries, then it seemed not to matter.....:confused:
I am getting ready to start up a new motor with a boiled out radiator and I think it is worth adding $4-5 of distilled water, at least to start.
Some of the crud could be precipitate from hard water. But who knows?
Ed
Did your F 1/2 drain easily, Ed?
I'm just surprised how universal (within my limited experience) this crud is. I get the sense that whenever it was done, ONLY the radiator and not the engine must have been drained by prior maintainers of these trucks. They probably figured flushing was good, and the way the coolant actually circulates that rear corner is a dead space, kind of like a bend in a river where crap gets deposited and built up.
I did not drain it from the block drain, just the radiator, then I ran some compressed air into the heater hose. I'll go take off the block drain and visually inspect it tonight. The head was pretty clean when I removed the sender and the water outlet.
ed
Ed
I would use a premix antifreeze. I use the Shell ROTELLA® ELC Extended Life Coolant/Anti-Freeze Rotella Products in both my cruiser and my turbo diesel. I will never go back to an antifreeze that requires water. The reason my head gasket blew was a stuck thermostat due to calcification buildup. You can only use this antifreeze after a complete flush of the coolant system. It is rated for 300K miles. I've had it in my FJ40 for almost four years and my turbo diesel for over 6 years and have had no coolant issues.
