Welcome, Dave is a good guy and he'll set you right.
Was finally able to get out to visit Dave and glean from his knowledge. Along with JohnVee's insight, it would seem I am not in a bad spot as far as my front end. Ironically, we found a complete set of missing engine mount bolts on one side, which may have been contributing to my sounds.So what happened? What's the verdict?
Sadly it's a trans noise. Put a screwdriver against it to listen and it sounds like a handful of bolts in a metal can. Noise doesn't stop with moving shifter and it's sadly not linkage or anything. It's internal issues.A rattle can be anything, John. Hell, there might just be a loose coin somewhere. Crawl around looking for loose bolts down below and $$$ up inside. And loose bolts there, too.
Does the rattle go away at idle if you hold the shifter tightly forward or back? Does it do it in any gear, or just park? Don't forget about the transfer case lever. Those can make noise. Someone just recently posted up about their TC boot working loose and causing a rattling noise.
Well $hit. I thought I was being a smart fella, and had all the fluids changed on my 60. All was well up until that point. My transmission shifted smoothly, and all gears worked seamlessly. Now though, there is a rattle out of my transmission when sitting parked at idle, and there is a noise in 4th gear, that is scaring me.
Sounds like there is a rebuild in my future. It still shifts well, no slipping, and no issues other than noises that should not be there.
So - given the wealth of professional knowledge out there - where is a good place in CLT for a reasonably priced rebuild? I don't really want to do a 5 speed swap, as I like the slow go of the 4 speed. I don't want to put a ton of money into this thing just yet, but do want it as a dependable driver. It has almost no rust, 215k on the clock, and only one leak at the rear main. 20w 50 means only one or two drips per week.
Any suggestions on a good solution that won't break the bank?
75/90 is fine. Check the transfer case shifter. The linkage to that can make a ton of noise. There are some nylon bushings in that linkage that wear out or get misplaced. If you can move the 4wd shifter and change the pitch or frequency of the noise you are hearing then you've found your problem. These old H42 four speeds are typically bulletproof. Usually the transfer case wears out a half million miles before the trans itself. Don't worry too much just yet. Bring the truck to cars and coffee in the morning and we will look at it. I'll be there around 7-7:30 until.
Once again, appreciate the base of knowledge. Used to driving $90k new cars. Big change.
Dave is awesome.
