If you need help lemme know Luke. I'm going back inside mines soon as I find me some E30 projectors & to adjust my shield to put out more light.
Now you see the dilemma I ran into, which is not getting the light through the stock hole. I found that I couldn't (at the time with limited time) fit the 3" projector behind the stock shroud and maintain a decent range of adjustability.This is a 3" RX350 projector... it doesn't seem like I'll need to cut to much but I'm sure the depth of the projector could change that based on Dirtdawg's experience.. I know the factory projector sits behind the shroud.
Luke111, I sure wish you worked in the Service Dept. at Lindsay. I took my 2000 LX there to get my rear springs replaced, and then after the replacement, wanted them to give me a reading on neutral pressure on the height on the AHC system. I might as well asked them to fly me to Mars, they had no clue what I was talking about. Literally had to get on 'mud and print out a screen shot from Techstream where it shows neutral pressure for the AHC system. Had to sit there with a Service Manager while he pulled it up. Went home and cranked the torsion bars myself to the approximate correct pressure. For what a dealership charges, they should know how to use the suit of diagnostic tools Toyota gives them on an expensive vehicle, but I guess it is not on the list of "standard" charges the service department uses.
You should bring it to our meeting at Kilroy's in Springfield next Wednesday..![]()
Why the switch? Every side by side I've seen the E30 is equally comparable to the TSX-R.I ordered some E30 clear projector lenses today. Hopefully they here by the wknd so I can put my surgical gear on & get to operating next week. Will keep you guys posted. I'm removing the tsx-r clear lens. If anyone interested in them they can have them
HID Projector plate is in progress. I met with the 3D guy today. He needed a headlight assembly to orientate the plate inside of the headlight... we'd really like to stick to the poly carbonate it's something he can produce locally so we're just trying to figure out what areas of the plate we can make thicker structurally stronger so we can proceed with the polycarbonate.
Here's a very early teaser The production one will have the offset mounting tabs
I'd be interested in a set
