kcustom73
Stretched it...
- Thread starter
- #201
I'm so bad at keeping this thread updated, but work hasn't stopped. Got the transmission plugged up and running. The 203 is installed and got the splitcase built up and installed. This took me little while to get done because of the front output oil slinger (forgot to install and had to order a new oil seal to put it in) Also got the twin stick setup installed, just need to paint everything.
Got the rear axle all buttoned up and the rear disk brake installed (raybestos rotors, Monte Carlo calipers and EBC pads). Also got the skid plate re-installed.
Also got the front end put together. Used knuckles & stock birfs from a 60 series, 4Runner calipers, EBC pads. 40 series TRE with starter bushing fix to make them work with the 60 stuff. Also got all the steering set up and installed a Trail gear steering stabilizer.
Got all the power steering lines installed except for the cooler and now I'm waiting for the last of my brake fittings to get the brake system done. The rear driveshaft is done and I'm waiting for my 2 piece front driveshaft after running into issues going with a one piece I'm hoping to take it for a spin around the block soon just to test all the mechanical's and give me a little boost to get it done for the summer.
