Three coats Cygnus White, sprayed today.
Anyone???
).Magnet man:
The line is where the clear coat has completely disentigrated from UV exposure. The majority if the hood & roof are exposed paint, as the clear coat has flaked off.
This is pre - solvent wipe.
Magnetman. I use epoxy primer from southern poly. After I shoot it, I typically wait 24 hours then apply the topcoat. For your product would it be the same in that I would not need to scuff the primer (it will bond with the primer without mechanical scratching?)
Thanks,
As a general rule you should always follow the recoat guidelines for the primer being used. I don't foresee any issues topcoating in 24 hrs
Most epoxy primers have a longer recoat window than this
Any chance on getting a tester batch of Cygnus white in 10-14 days or should I look for other options?
Need to get something to match. 10 -14 is possible
Is this something you need me to take action on? I apologize if I misunderstood, I thought you were going to order the ebay sample card or go to ACE with the mix. Did I miss something?
This might be a dumb question but, do I need to mask twice (one for each coat of monstaliner)? If I wait six hours between coats might the bit I get on the masking tape cure too hard to remove the tape after the second coat? I'm going to be rolling black monstaliner on my fender areas tomorrow. Sanding, MEK, masking and drop sheeting are all done.
Explain better, is this a 2 color job or just black?
