Methanol Injection: What Are The True Performance Gains?
I think with the injection, a 2.8 pulley would be fine. If the injection system ever failed, you would still be able to baby it along. That is assuming it's an obd II truck. Obd I runs leaner so I hear.
Super cool. Thanks for the insight guys. It's cooling down here in northern NV, so I'm going to first try a couple of pulley sizes per scottyrana's suggestion regarding knock monitoring. Then I'll go with the meth injection in the spring....
i need to make a custom pulley puller to get my stock pulley off, otherwise, I will have to pull the charger to get a normal puller on it. Just gotta make time to do it. I've got my snowmobile pulled apart and it's almost winter, my daughter's 80 in the garage for a head gasket (for me to drive this winter) , and lots of firewood to cut. Minor setbacks
PS- here are the full measurements, now confirmed with Pulley Boys, on the stock pulley-
4.5L TRD Keyed Pulley
Pulley Boys Six Groove Keyed Pulley for 4.5L TRD Style Supercharger Kits
Stock Size is 3.25"
Available in 2.8", 2.9", 3.0", 3.1", and 3.2".
Nose Drive Pulleys Fits:
FZJ80 4.5 Liter 1995-1997 Toyota Land Cruiser TRD Style Supercharger Kits
Made from hard anodized 6061 T6 billet aluminum.
Only available in black.
18%
SKU 6KA
Weight 1.00 lbs
Pulley Type Keyed
Pulley Offset 0.4" (10.16mm)
Pulley Grooves 6
Shaft Diameter 0.64" (16.256mm)
I think he meant he lost 2 seconds as in 11 secs down to like 9 secs.
huh? please explain, logic would seem you would be going faster, ie: more boost???
I just dropped in the 2.8" pulley wheel and have noticed a positive difference, albeit subtle, going uphill. No knock, no codes, everything looking fine in fall weather. I am dubious I've gained anything beyond a second on a 0-60 pull.
I'd take that second. Nice
Sure. I'm not complaining... But the next step is the meth injection.
Guys, I forgot to finalize this thread... I did wind up getting a 2.8 pulley, which consistently pulls at about 5-6 PSI based on my cheapo boost gauge. I will be purchasing the Snow Performance meth injection here shortly... and ahead of Cruise Moab ;)
landtank, sorry, what are you running? sc? meth? advanced / non-stock timing?
