- Thread starter
- #341
hour
I'm not going to clog up Don's thread, but will start a new one in due time. It's going in the shop shortly after Steve leaves.@samc2447 , Steve is looking very good. But when you get a chance, would you be able to expand on the work done here? as I don’t recall seeing any posts pertaining to it.
I'll post more pictures and details a bit later. The engine swap was the primary focus. Ton's of little things, inducing chasing down and repairing wiring faults. Just wrapped up relocating the steering stabilizer mount since the conversion done previously used a 60 TRE the factory frame mount was too close and wouldn't allow proper articulation. Also added a power steering cooler for the 80 series steering box I put on.Let me start for Steve, removed original motor from this 1974, cleaned engine bay(including some rust work, installed Mosley motors 2F w/new 5 spd and split case, new driveshafts, Sniper, Dui distributer, A/C seats, new mosley radiator, Alternator, plus a ton more little things. All yours Steve
Yes, VA high flow system for a 40 series. Basically bolts right in under the dash. Core support modifications needed to get the condenser in front of the radiatorI might have missed it, but what's the a/c setup? A Vintage Air 40 series modified to fit?
How far are you?See you there Ron
