Build Meet Steve
I used this method for my box. It worked very well.
Thanks @wngrog had a quick tech support chat with @FJ60Cam last night. He suggested a bit more timing then adjust the IAC. All good now. This thing pulls hard.
Steering issue was a bad 60 rebuilt box that was on it when I got it. I had bled it properly to ensure it wasn't air in the line before I drove it. Don reported the same issue before he brought me the truck. I didn't have the right bolt pattern 60 box in stock, but had a freshly rebuilt 80 box, so an upgrade for Steve. Steering is on point now. Going to add a cooler since it doesn't have one.
I don't want to put the hood back on since @FJ60Cam 's engine is such a work of art. Pretty sure it will make it on sometime before @Pigeaten picks it up.
I just need registration stickers so I can venture out further than my neck of the woods to put some miles on it.
Awesome. Did not realize it was you doing the install. Nice work as always.
Let me start for Steve, removed original motor from this 1974, cleaned engine bay(including some rust work, installed Mosley motors 2F w/new 5 spd and split case, new driveshafts, Sniper, Dui distributer, A/C seats, new mosley radiator, Alternator, plus a ton more little things. All yours Steve
I have no doubt you will make it home safe , But you might ask the engine builder about changing the engine oil some where on the way home ? (500 miles or so ? ) Might also need a engine oil additive ? Be safe , We look forward to seeing it
