why would it be more difficult to design a lift spring for the 55?
I can’t speak to the others simply because I haven’t spent any time measuring them for springs. For 55’s specifically the spacing of the factory spring hangers is fairly close and to get medium to high lifts you start arching the springs into a substantial U making a spring over an attractive alternative if ride quality is a concern, another issue is the short shackles and their ability to have the range of motion with the longer main leaf that would be needed for a proper medium to high spring only lift, the rear would be pretty straight forward with just a longer shackle but the front is a different story, 55’s have something like 1.5° of caster and adding any length to the front shackle decreases that number killing drivability again making spring over an attractive alternative.
I’m not pretending to know everything but I have spent a considerable amount of time and money chasing the dream of keeping my pig spring under for a lift that’s fractionally higher than the Cruiser Outfitter’s kit in the front and it’s not as straight forward as it appears, I would have been money and time ahead to strip all the factory hangers off the frame and build a complete custom setup or just live with the kit as delivered because it actually worked pretty good.
(Edit to add) I personally believe the Cruiser Outfitter 55 specific lift kit is about as high as you can go in the front for a complete bolt on SUA kit and still keep the 55 usable on and off road, shackles are on the verge of inversion at compression and caster is decreased to around 0.5°. I ran these springs pretty hard in the beginning and the shackles never inverted on the trail but flexing the pig with the forklift they would get close. Caster was corrected with shims.
Just for clarification I’m running 35”X12.5” tires with rear Cruiser Outfitter springs as delivered, the front springs needed about ½” more lift to sit level and with the 35” tires moving the front end forward 1” helped with tire rub at full stuff so those springs are a combination of the OME springs and a new main leaf with 7” long shackles and relocated mounting points.
This setup has very good ride quality, very stable at speed (I’ve had this pig over 100 MPH), flexes very well off road and overall I’m happy with the outcome.
