Build Lynchburg Lemonade, matzell's STW
a few more pics.
Rob I haven’t been able to get mine to flex past 9.5-10”
Worn out bushings usually allow more flex.
Grinding the tops of the control arm helps.
Not sure if you did that but it doesn’t look like in the pictures.
Grinding the tops of the control helps.
I think I may grind on the arms a little and install new bushings in another set of arms that I have laying around. and try them. These bushings are not torn, or at least were not when I installed them, the rubber was just really hard. I am more happy about the comfy ride over flex at this point!:)
The ride is MEH :flush:
Kidding, kidding, kidding.
It is night and day from mine, as it should be.
Seriously though. It rocked. and I bet will be even better when he links the rear.
I poked around this a little this weekend, nice job Rob!
I replaced the fibreglass part of the roof. Some dirty animal cut in a stupid sunroof.
My gutter was fine. No appreciable rust.
If I were to do it again today, I wouldn't rivet the gutter in. I'd just glue it down and not deal with the liability
After some time off I was able to work on this some more. I got all the holes marked and drilled. Then welded some weld nuts to it. I have some finish work and welding the bottom, then I will join the front and back and fiberglass to it.
I hope to have this done by SAS in August.
I used a rivet setting tool for my air hammer I bought off Amazon. That and a body dolly made quick work setting the rivets. I also love my Matco drills that keep eating through metal.
I had to repair a crack in the fiberglass. Two sheets of glass and it should be good.
I used my new HF material remover to get off the foam and glue residue from the inside
