Loose Bolts
The Ghetto
I'm always having to tighten my rear driveshaft bolts. Usually once a month or so. Is there a reason they're loosening up on their own? I'm thinking the shaft is out of phase but i'm just making sure.
If you have lock washers, I would change over to nylon insert locknuts. With metric bolts use class 8 or 10 locknuts. If you have SAE bolts use grade 8 locknuts.
Like you said, confirm that the drive shaft is in phase and that your U-joints flex with little resistance in all directions.
And, blue loctite.
Locktite. ;)
Driveshafts "in phase"? What's that about? Before I pull mine to check spiders, it would be nice to know.
U-joints are in line with each other. Not slightly cocked one way or another.
I would avoid nylock nuts. They won't fall off but my experience with them has shown they still and can loosen up enough to allow the slop again.
I would rec. balancing, check phasing, then put back in the metric nuts and bolts.
Mine did the same until I went to the bolt shop and they gave me some acorn locking nuts and I still used blue loctite . No more loose bolts.
I bought some brand new OEM driveshaft bolts from Toyota, but found out they didn't fit my year (I have the small bolts) ..
They are just sitting in my office waiting for a home :D
OEM is really the way to go,, not having the right shank causes vibration, which causes bolts to loosen.. Get the right bolts and a little bit a loctite, and a couple busted knuckles. Problem fixed..
:cheers:
:cheers:
x2. But I would also check the phasing. Generally, unless the driveshaft has been rebalanced or retubed, the grease zircs should line up perfectly as well as the "U"s being in line.
