Kurt, not to hijack but the odds of this working on a GX are slim and none, or a comparable kit? Just wondering. Thx!
Correct Andre, I believe that the GX do not have a hub and spindle but rather a unit bearing in the front end, so you wouldn't be able to bolt on the hubs.
Sorry to continue the hijack... but...
There's actually a couple different kits out there that convert the 2nd/3rd Gen Tacoma, FJC, and 4Runner to manual hubs. The old school manual-hub hub-body from the 1st Gen Tacoma fits right into the unit bearings on the newer 120/150-platform trucks. The deal is, you then can use either the same manual-hub 1st Gen Tacoma outer/bell end of the CV and a custom shaft with new appropriate splines, or a new manual-hub outer/bell end of the CV with appropriate splines for the original 2nd/3rd Gen Tacoma shaft. The GX shares identical front axle to the 2nd/3rd Gen Tacoma so these kits would fit right up to a GX.
*AND* then you need a part-time case. The GX (and the V8 4Runner) are full-time 4WD with center locking torsen diff, and there is currently no center spool option to swap in that I've heard of. *However*, GX, Tacoma, FJC, 4Runner, 1G Tundra, 1G Sequoia, LC100, Hilux, and LC Prado share transmissions and motors across them and if one wanted to mess around getting a part-time case into a GX470 the part-time case from a part-time 4WD FJ Cruiser with auto trans would bolt right up. The interior console stuff and computer stuff is another story, but i feel could be worked out if one really wanted it.
We prob should start a new thread though if we wanted to keep talking about the GX...
