- Thread starter
- #181
You won't lose much coolant and good luck trying to catch it. Its going to spill all over the place !
At $8, this might be more of a 100 series move but I used this stuff on my Koso gauge and the digital voltmeter for my house battery. It tones down the brightness so they aren't distracting at night. Dim It light dimming sheets - Alarm Clock Dim - Amazon.comThe only thing I havn't like about mine so far is its very bright at night.
Amazon here, I will see if I can dig up the old records. Seems @DSRTRDR / @ChaseTruck had a similar ordeal. Maybe they remember better than I.So, when I went to do this I discovered that the inline adapter and my sensor were threaded differently. It was last fall when I did my phh and most of the other cooling components and I haven't looked since then, but I seemed to be unable to find the sensor threaded correctly to fit my inline adapter. I returned two different adapters to Amazon, but kept the sensor figuring I'd just tap into the metal line with my next coolant flush and fill, but I'd prefer to go with the hose adapter route. Where did you guys who have done this recently source your hose adapter and sensor?
.Koso says the resistance reading across the connector terminals should be 10k ohms at "room temp". I could try both.take a glass of water with ice in it. make sure to stir it well. put the sensor in and see if it reads 32*F.
thanks to the properties of a phase change from ice to water, it will always stay at exactly 32*F until it is all thawed (assuming it's mixed thoroughly).
edit: for something closer to engine operating temperature, use boiling water. make sure to account for the change in boiling temp as elevation increases
It is like Toyota left a flat spot for the Koso Temp Sensor! Nice and flat and facing upright.
Took longer to remove the distributor than to tap and drill hole for sensor
I'm interested to know if anyone else has had the same feeling about their gauge.
Hornd
I would advise you to change your temp sensor location to the other side of the engine:
this is a "reverse flow" system, it puts hot water into the bottom of the radiator and cool comes out the top. Why Toyota did this? not really sure, but maybe to reduce the chance of getting burned if you touch the upper rad tank.
The result: your temperature will be reading at the lowest temperature in your system (right after it's cooled down from the radiator) and is not very helpful in indicating an overheat condition since you don't know the actual temperature of the coolant coming out of your engine.
Where did they put the overflow and pressure cap on this radiator?
