I also added the felt tape on the edges of the top panels and the side wings to eliminate any wood-wood squeaking. The tape is super thin so it doesn't add hardly any thickness to the gaps.
That stuff's kinda thick at 1mm. The stuff I used is 0.2mm thick: https://www.amazon.com/Tesa-Adhesive-Wiring-Original-Isoband/dp/B00XPBB6L8/?tag=ihco-20is this the felt tape you're using?
https://www.amazon.com/J-V-Converting-FELT-06-BLK15-Polyester/dp/B00ZBH3QIU/?tag=ihco-20
Yea, some of the squeaking was definitely related to the hinges.@Ayune great suggestion on the felt tape! I've got to say though, my set isn't squeaking at all even after all this time, was the top perhaps a bit loose? If the screws aren't threadlocked they will definitely loosen over time and then maybe squeak... With the hinged wings though I know that happens and I'll add your tape to the customization page of the website, thanks for sharing!
It isn’t. Top mat stays put on its own. Cut out a shop type mat from Lowe’s. It was a little pricey, 60 bucks, but the bottom rubber is muck grippier than the cheaper ones. Had it on two trips now, doesn’t really move. Was gonna secure it with glue but works so well I like the idea of being able to remove and shake out as I have two golden retrievers. The other piece is extra I move to the tailgate when getting on it. I have been leaving it on top the other mat for now.@Marleyboard how are you securing that mat on the drawer and the tailgate?
The actual size of my KISS Drawers' top surface is 42" x 59" including the wings. I have the non-rear AC version of the drawers if that matters.What size should I buy for the top rubber mat? According to drawer spec "Top: 59"W x 42"D", 4'x5' should suffice. But looking at recommendations here: Land Shark Outfitters
A bit confused, should 4'x5' suffice to cover the wings as well? There's now about $12 difference between the 5' and 6' so if 5' would work I'd want to save a bit.
- Rubber Mat: 1/8x48x60"
- PVC Flooring: 2.5mm (1/8") x4' x 6'
what's the measure of the center piece?
Trying to figure out carpet sizing to buy. a lot of it is 72x36 or something. like this https://www.amazon.com/Marine-Upholstery-Durable-Backed-Automotive/dp/B07175S25Q/?tag=ihco-20
another seller was out of stock but i feel like it'd be the perfect amount https://www.amazon.com/gp/product/B0058P70PU/?tag=ihco-20
I'm only looking to cover the top surface in carpet. I'll do something else for the inside of the drawer
what search terms do you use for lowes?
