When nailing in the slides to the drawers, there are no guide holes (step 12). Do the slides line up with the bottom of the drawer side? Or is there a space between where the slide sits and the bottom of the drawer? Also, how far from the front/back do the slides sit on the drawer?
Are there obvious differences between the long aluminum pieces (besides length)? The instructions say that the ones with red tabs (step 19) are "rounded" to allow the slides to move undamaged over them, but I don't see any difference between any of edges on this or the other aluminum pieces. Maybe all of the aluminum pieces have rounded edges? I can get a picture of the aluminum pieces if this doesn't make sense.
I just did this last week so I think I can answer your questions:
The "guide holes" are located on the plastic slides,
Easiest technique is to hammer the nails into the pre-drilled holes on the plastic slides until the nail just appears on the other side. Place it centered on the drawer, as measured using the guide tool and instructions, flush with the bottom and hammer them in as instructed (inside to outside). Repeat for the other side then slide the guide tool along the rails and if it binds then you've made a mistake.
All of the aluminum pieces that are used to build the drawers are rounded on one side. The square pieces are for the frame. Did I understand your question? Or are you referring to another difference between the aluminum pieces?
