Heard, I can't tell, lol. As long as the fitment is the same.
I've always wondered how you'd mount a light bar with this rack. How is the wind noise with the lightbar?
Your paint looks fine. Did you prime first, how many topcoats? Did you paint it before or after assembly?The rack is aluminum and if it looks rusted it's because I can't paint worth a crud, I missed a couple spots underneath there. t's pristine and very, very clean aluminum. Just a good picture of my poor rattle can skills.
Take this for what it's worth, but as you know I have a Prinsu rack, but I also have frequent contact with well known distributor of the K-9 racks so I get to see them somewhat regularly and see it get used as "aggressively" as any of us would use one.Been looking at this and Eezi-Awn K9. Anyone have any comparative experience?
Take this for what it's worth, but as you know I have a Prinsu rack, but I also have frequent contact with well known distributor of the K-9 racks so I get to see them somewhat regularly and see it get used as "aggressively" as any of us would use one....
I can't think of a K-9 that I have seen first hand with a light bar. But Prinsu has designed his racks with lightbars in mind and should have a lightbar friendly version of the wind deflector as an option. I have a 40" lightbar on mine that I added at Christmas time. To mount mine the way I wanted (no higher than the rack) I removed the wind deflector altogether but have use the deflector crossbar to mount the lightbar. My lightbar is a dual row and keeping it low put it very close to the roof. I put a strip of foam weather stripping on the bottom of the light just in case it contacted the roof. So far so good and it's working great. There is another guy on here with a lightbar on his Prinsu as well. I've forgotten his username. Edit: It's @Haring Bagsik , he has posted in this thread.Thanks for the extensive rundown. I guess my remaining question would be--have you looked at light mounting options on these, or seen rigs with light bars on them?
Thanks! The other photos of seen of your rig had no light bar. I'm also a fan of low-profile lights. If you take any closer shots, put 'em up!
Talk about a late response, my apologies. I did not prime or coat, just plastidip and it still looks great, well, nothing I do is great but it looks good.Your paint looks fine. Did you prime first, how many topcoats? Did you paint it before or after assembly?
Regarding the roof ribs, the rack itself fits fine without removing them but I added a Renogy 100W solar panel that I've shimmed to fit just barely below the top of the crossbars and the panel is either sitting on the roof ribs or just a hair above them. I recommend either using the uber-thin roll up style solar panel on a custom low profile mount or consider removing the ribs if you want the panel to sit below the top of the cross bars.
Has to be a mistake. They're all equal lengthWe're trying to figure mine out right now... 9 cross bars, two are 2" longer than the other seven. Is that a mistake? We thought maybe it "flared" somewhere, but doesn't seem right. TIA
