Is anybody still interested in a center console?
Too late now I’m 6hrs away.
First round of test colors came back. The brown is NOT a good match but the gray is. Website has been going through a lot of changes, will be adding these to the site very soon. Arm rest covers are going to be delivered today, shift boots for the next batch of shifter consoles will be here, about to start selling them.
Turns out switch pro style units fit quite nicely in the same spot gauges would go, for those who don't want/need gauges:
Just for fun, going to do some testing of the knock-off switch pro to see if it's even worthwhile to make our products fit it. It is slightly larger than the actual switch pro (and way lower quality):
And finally, for those who have RHD vehicles, you might be interested in this test fit pic:
yes, I will be posting that shortly.
yes
Mmm. But I also want lots of USB chargers so my wife stops unplugging my tablet running Gaia maps. Where can I put the chargers then...I assume there wouldn’t be room for 3 gauge, switch pro and usb chargers right?
Actually just realized the pic above is with the larger knockoff switch pro. With the real switch pro it looks like there may be enough room to put it to the right of the 3 gauges and keep the 2 usb holes over on the right.
I'm going with "no". But that IS what the 6 punch outs in the center console are for. Plenty of spots to mount those.
on edit: the pic with the knock off one is a 2 gauge plate
I have been waiting to put my interior back together until i get one of these.
what if the usb went up above the switch pro and the switch pro was moved lower down on the panel?
How do you plan to seal the openings around the openings, particularly
around the shifters, foam strips?
not really. can show you when you are here. the switches, etc need room around them.
Will it fit with a Tuffy 013 with cupholders in front, Tuffy positioned so rear seats can tumble forward?
Also--are there alternate punchout patterns or solid plates for DIY?
