Intermittent code 26
Post is too long to reread to see if you checked the plug connectors.
I had corrosion in one of my plug connectors. The corrosion worked its way up the wire under the wire coating. Had to cut back the wires till I got clean wire.
I did check the wires and the continuity in each of them. They all tested out fine. The light came on and stayed on for 2-3 days. I went to drive it this Am and it was off and stayed off. It's inpredictable. I'm going to take it to a specialist after the holidays for another set of eyes and ideas.
Mine ended up being a corroded ground splice in the harness. It was the ground for the tps afm and egr. Had 49 ohms to ground. The problem was intermittent and tested fine when I first tested the wires. It runs perfect now and passed smog no problem. Money well spent.
Mike at BMR emailed me back about my issue. I will be taking it to him after the holidays. I hope he can find my problem.
light came on this am on the way to work while stopped, an as soon as I starting driving again it turned off :/
Different code but same symptoms mine had. I ended up having him do a bunch of additional work on mine to make it pass smog. New intake boot and afm adjustment. I was burnt out. Want to start worrying about lockers, gears, body armor and tires, not electrical issues.
Still haven't had time to take it to get looked at since Im still getting my cobra back on the road, and I hate driving it in the rain.
Still getting the light going on and off for no specific reasons. It is really leading me to believe it is the O2 sensors. Has anyone else had issues with the Denso oxygen sensors on their 93-94?
Im temped to buy another set of NTK to throw in and test out.
I was getting same code 25 26 intermittently, replaced with the Toyota 94 sensors kit, which is ntk, codes have not come back, I also removed the pair system and stuck the o2s there, if the pair system is staying on could mess you up throw those codes possibly too.
I know there was special service bull item on the original sensors they put in the 93 94 years so maybe if your buying aftermarket ntk your not getting the newer ones?
I'll be relieved if it is the sensors, but irritated at the same time since I spend $290 on the pair of them. And I think the toyotas are about the same price:/
NGK are good. I bought a Bosch from Autozone and in the box was a brand new OEM Toyota O2. I guess it was a freak thing cuz I bought two and only 1 was OEM. Bought a coil there and it was OEM brand new too. I'll look in my bone yard to see if I saved the spares.
Note: the Bosch direct fit made by Bosch was the wrong O2 for my 80. I told them to keep it and am still running one NGK that was already on my rig and the new yota one. No codes
in the past I always used the NGK. I had heard that the Denso would last longer so I tried that route. I kept all my old sensors, so I think I might just have to play with them and see if it remedies the problem. Or ill shell out 120 and order a new set from rock auto.
See post #45 on my latest fun with code 26. Maybe this will finally solve me going thru sensors every 4-6 years.
When it rains it pours.....
Damn! makes me want to just take it in and have it looked at before I throw unnecessary parts at it. :(
was it something you could see? or did they have to take the harness apart?
I could have paid to have mine fixed by the mechanic 5X over with what I spent throwing parts at it. I felt kinda weird taking it in but I would have never figured out the problem. I cleaned all my grounds but the ground that was the problem wasn't a body ground it was an ECM ground.
With the precise engineering is on this rig I'm really surprised how bad this harness is. Seams to be the weak link, with bare factory splices inside and runs right next to the egr. From the problems my 80 had and what others have posted your problem really sounds like wiring.
Not sure. SD Trux isn't like a dealer that'd just throw parts at it. They bench tested the sensors and voltage to sensors somehow discovering the 1 volt surge to #1 O2 where the sensor harness plugs connects in the engine bay. Honestly, I haven't even looked to find the new connector! To bad you are in NorCal and SD Trux is down here! IMHO, well worth my 60 mile one way trips to see John and his crew. I've thrown them some whopers in the past few years and the truck always comes back running as well as the day I drove it off the lot in 1994.
Brent I looked at your other post mentioned and I am a bit confused. To confirm, what they found was the heater circuit in that O2 sensor connector was feeding voltage into the sensor circuit. Correct?
I just went through a code 25, but with a misfire. It ended up being an injector wiring housing that was broken. This is not your problem, but I made a list of what to check for a code 25. I was doing it ass backwards trying the easy diagnostics first and then succumbing to pulling stuff. Here is the list from the FSM. I annotated it with what I think you've done.
1. Engine ground bolts loose- I think you checked those, but did you also look at the ecu ground carefully? The one on the air intake.
2. Open E2 circuit- I think you tested a different ECU, but did you go through the tests for the harness? This is for the EGR temp sensor, Engine Coolant temp sensor, TPS and VAF.
3. Test the injector circuit. Ground side to the ECU. Follow the FSM, but also test resistance. Make sure they are the same across the board. george-tlc helped me in that if there is an intermittent short on the +12V side the EFI fuse would blow. He also warned me about grounding the injectors as that causes them to open up in a way they were not designed. I followed the FSM. It will help to pull the throttle body to actually access the injector wiring harness. You need to do this anyway to test the injectors.
4. Injectors. Have you put a stethoscope on each of the injectors? They should all have the same click-click-click. Since you problem is intermittent this may not work. With he throttle body off you can test the resistance of each injector.
5. Fuel Line pressure. I was girding myself to do this. The FSM way has you getting putting the gauge on the firewall side banjo fitting of the fuel rail. I hate that banjo.
6. VAF meter.- you have tested yours and others. Maybe the harness? should show up in the E2 circuit test.
7. Pair system. There are some vacuum lines and a vsv for this. There is a test in the FSM for it, but you need to pull the reed valve. It is work checking in addition to the wiring.
8. Heated oxygen sensor circuits. Really go through the FSM test for the circuits. Some are with the truck running at the diagnostic port.
9. Heated oxygen sensor. I think you have that covered. They have the right resistance.
10. Ignition System. I see you have done a tune up. It might be worth the money to have someone use an oscilloscope on the primary and secondary ignition. I can't interpret them, but with an obd1 it is a quick way to rule it out.
11. ECU, you've covered that by trying another.
You might be able to rule some things out by going through the test on EG-227 for the "Open or Short in Heated Oxygen Sensor" and EG-228 "Open or Short in Heated Oxygen Sensor, Open or Short in Injector Leak, Blockage, Loose Engine Ground Bolt". Maybe rule some stuff out?
I was lucky that mine was easy and not intermittent. I think you are going to have to be super systematic on this.
Dan. As best as as I recall from what they said, yes.
