Intermittent code 26
I can loan you my brand new Toyota O2 to save you money. Let me know if you want it I'll pull one.
Damn thAts crazy! 378!! I appreciate it. At this rate I'll just keep it. Either way I'll end up needing it. Thank you for the offer though! I appreciate it
UPDATE:
so I just got word back from Mike that my truck is ready to go.
He tested my Denso with less than 1k miles and another set of O2 sensors and could not get them to work out. He ended up getting a toyota branded sensor from the dealer and it worked without issue. He told me that my Injectors still may be an issue very soon, So I plan on getting my truck smogged this week and then I am going to tear into the sensors, get them serviced and cleaned and replace everything involved with removing the upper plenum.
so almost $700 later We found the issue!
Let me know how that goes. I need to pull my plenum to get to the harness and am not looking forward to removing the bolts from under it. Wonder if some injector cleaner would help?
I replaced injectors about month ago. It can be done in half a day. I have pulled apart top half plenum three to four times now.
Ouch but good news. I may have called him today haha
oh yeah? haha nice. Well thank you for the reference!!!
I dont think its very hard, Just a pain in the ass.
nice. I will take it apart and Im sure the injectors will be out for a few days before I can get back to them. but while they're being serviced I'll replace all the hoses and stuff underneath.
As long as you had this problem, you never tried O2 sensors from the dealer? I thought you had.
Did Mike tell you what the compression numbers are?
No,
I thought the densos would've fixed the issue and then when the ntk sensors failed( which is what I've always used on the 80) I didn't think it could've been a sensor issue.
For the first time in my life I was wrong.
I had a good roll for over 30 years through! Hahaha I didn't have him do a test. I'll do that myself. Save as much on labor as I can.
I had two bad densos on my old rig brand new out of the box returned the second for NGK and no problems. Isn't the Denso for an 80 ridiculous expensive too?
Yeah this one must've been bad right out of the box also! They are 140 each from rock auto.
well from now on it will only be OEM.
I really hope I wont have to mess with it for a few years now. So crazy that the NTK sensors worked for so long.
Crossed fingers that you've solved your issues. I had them and have always used nothing but OEM. Go figure!
So the saga continues....
Picked up my 80 this am and all was great until I was on my way to work. Light popped on and showed same characteristics as the last time. light was on at the stop light, and then went off after I accelerated and it stayed off the rest of my trip to work. Called Mike at BMR and he is going to hook me up on the diagnostic since I just had it in there. We think it may be one of the front 3 injectors being out of spec. Waiting on my LC part hook up to get back to me about some used ones. Mike will swap the front 3 out for me and then well see if that solves the problem again. Although my problem hasn't been fixed YET, Mike has been great.
Original injectors? Why replace only three after going to the trouble of getting to them?
because they can be replaced without removing everything.
part of me does want to get all 6 serviced and replace everything at once.
but at least the issue will be solved ( hopefully) and then I will go back at a later date and remove and replace everything.
How hard is it to get a socket on the bolts holding the two plenum halves together?
Not hard really, you just need 30-36" of extensions. I can't recall having to remove anything to get to them. Maybe the tranny dipstick, thread some wiring harness sorts of things. It is far harder cleaning it up than removing it.
Removing the intake plenum is very easy and only takes a few gaskets if that is keeping you from doing all of them.
I removed all my injectors and tested them my self and had it all back together in one evening.
