Intermittent code 26
Thank you for the input. I'm contacting a few local mudders to see if I can try one of theirs and make sure that's what my issue was or is.
Is there a company or individual that refurbishes the old vafm?
In the 6 years I've owned my rig I've never touched the vafm other than when I remove the intake hose. So I'd hope that's not the issue. I'd just love to have a working vafm and an extra refurbished one just in case
Damn,
So I just swapped in another vafm that is within the factory specs, reset the ecu and the f&@$ing cel just popped back on after 10 miles. I'm ready to drive this thing off a cliff.
Looks like it's O2 sensor time. :)
They are brand new though.
In December I was getting the same problem and I thought it was the o2 sensors. When I swapped em in it didn't fix anything. So it's another issue that isn't showing its head anywhere. All of my wires And connectors are good. Even the ones behind the egr
is there a way to test the O2 snesors just in case?
thanks
The FSM tells all. What about the stretch of wire to the inboard O2 sensor? That wiring is routed over the transmission. Mine looked beat up. I can loan you and engine control unit to try out if you get frustrate enough.
Man,
I'm going to check that wire routing one more time and I think I will take you up on that if I come up empty handed.
Thanks
wires look fine.
I printed out some pages of the FSM and I will run the O2 terminal test and see that they are getting the correct readings. Just in case It ends up being my brand new O2 sensors that are bad, where is everyone getting their Denso/OEM sensors?
thanks
I bought a pair from Cruiserparts.com. IIRC, I paid $290 about one year ago.
So I did the O2 sensor test per the FSM pages EG315-316.
First of all none of the sensors tested 5-6.5ohms when at 68*.
So I ran the test with the engine at 2500rpm and terminals e1 and te1 jumped. I could not get the volt meter needle to fluctuate whatsoever. So I had my fiancé hold it at 2500rpm while I jumped e1 and vf1 and then vf2. Both came up over 0 volts. Which came to the conclusion that the sensors Are bad. My first question is how can they go bad that fast? 1 is 3 weeks old and the other is 3months old. Is it possible the NTK sensors were bad from the factory?
I kept all of my old sensors over the years and I figured I'd test them out and a couple of them show to be in range. I'm going to first try those and see if they will get me by for the time being until I decide to break the bank at spend 300 on some denso's.
I revitalized a set of old O2 sensors by heating them just to the point of glowing with a propane torch and then dunking them in water. The rapid heat-to-cool cycle caused the buildup to crack and flake off.
I was pretty nervous doing it as it seemed harsh, but reasoned they get at least that hot in the exhaust stream. It pulled both my sensors back from throwing codes and into functioning properly. Another sensor I did it with it did not help, so YMMV.
With the amount of time youve been running these buildup is likely not your problem. But trying a free fix before you buy new ones may save you some $.
Glad you are into something. OEM sensors all the way!!!
From what I have read here, only use OEM O2's. Many have had problems with aftermarket O2's.
Rotella T6 is good oil but the added ZDDP (zinc) coats the catalytic converter and O2 sensors.
My motor uses oil, I use T6 oil and have intermittent code 26. I removed the cat and O2 and cleaned them in a solution and passed emissions test after failing. I still have the intermittent code 26 but only if I drive city miles for a tank or two of gas. After driving all hwy miles the light turns off and stays off till I drive city miles again.
To quote myself.
Nice. I'm going to clean them up and give it a go! I'll post up the results
Thanks​
And the result?
Thanks​
Did you try the acid wash on your sensors?
Hey guys. Just swapped in an older o2 sensor in this am. The one I pulled out was brand new but it had a a flat spot on the corner like it had been dropped. Took it for a drive and about a mile later the CEL turned off. Hopefully it stays off now till I can get around to buying some new denso's!
Thanks for all the input I really appreciate it!!
check your timing, and check at the base of the harness side of the o2 connector, my shielded wire was broken right up against the connector, I am fixing it now..
