Intermittent code 26
Fuel Pump Relay
PURPOSE / OPERATION
The fuel pump relay receives a signal from the circuit opening relay and supplies power to the fuel pump.
PURPOSE
The circuit opening relay provides power to the fuel pump relay.
OPERATION
One coil is energized when the key is turned to the start position. The relay contacts close and power is supplied to the fuel pump for starting. Once the engine control module begins to receive a signal from volume airflow sensor it grounds the other coil which continues to hold the contacts closed after the key is released to the run position.
I am aware of the circuit opening relay. It was not referred to as such hence my question about a relay I had never heard of before. Thanks
What is this relay's function? Where is it located?
It is located below where the flasher relay goes under the drivers side kick panel. My new one should be at home in the mail box when I get home. Very eager to throw it in and see if that will solve my long pain in the ass issues........ and the ones with my cruiser!!
Ok so I replaced the circuit with another unit and it hasn't changed anything. I checked to see if all the injectors are functioning and they all are.
Running out of ideas. I'm going to try and do the compression test this week.
Is there an on vehicle test for the O2 sensors? I know you just changed them. I also know your milage is north of 300k. A small amount of coolant escaping the HG could be contaminating your O2 sensors.
Yeah there is an on vehicles test. I may try that.
I'm about to find someone who knows what they are doing and take it to them. And btw my light has been on for 4 days solid. Just drove it 3 hours up the coast with no drivability issues at all. Just want to get the damn issue fixed.
@93yotasr5 I'm chasing the same gremlin at the moment. 94 with 308k on it. I know it's a bit of a haul from Sac for you, but Gary @ Mudrak, in Sonoma, is the guy you want. Shop info here: mudrak.com
Nice. I might be contacting him soon if I can't figure this bitch out.
I tested all the plug wires and they are all within spec. Waiting to hear from someone locally about swapping out the ECM and seeing of mine is bad.
So I swapped in a different ECM. Worked great for the last 2 days of driving with no CEL. On my way home from the store it showed its face again. Only code 25. I'm running out of things to test.
today I ran some diagnostic tests for the O2 sensors to make sure they aren't bad. the O2 sensors tested OK but the things that are suggested if the O2 sensors weren't bad was: engine grounds, injector circuit, blockage ( don't know where or what that refers to)
The code seems to show up after about 20-25 miles. I reset the ecu again and drove it this am to see if I could get a better idea of whats happening. After resetting it, I unplugged each sensor to see if it'd throw a code and it showed code 21( oxygen sensor) then plugged them back in and waited until the light disappeared. After driving it around for a while is when the code 25 came back. 26 has not showed back up again.....yet
I am wondering if the fuel sock to the pump could cause variable pressure to the lines therefore causing a code to show up even though I don't notice any power surges or misfires?
I am going to replace it anyways. Just curious what everyone else thought. I will tackle that job tomorrow.
I get the feeling you have something stupid simple going on that is just skating past you. I have had the same thinghappen when doing a head job when I worked in a shop. Just missed one tiny ground to ICM which made the truck a no start.
Of course im drunk and its friday night so your mmv. :cheers:
I'm thinking it is too! But the thing that makes me think it isn't a ground is that it runs fine even when the light is on, and it takes a while for the light to turn on now. If it was a ground I'd think it'd be on a lot sooner after resetting the ECM. I replaced the fuel sock last night. My old one didn't look as bad as I thought it would. I'm taking it up to truckee in a few to go cut a tree. We'll see if that helped anything or not. I'll report back later
So I drove it quite a distance today. The only time the cel came on was on the way home. I stopped and was parked idling for 10 minUtes or so. When I started driving the light turned off and stayed off the rest of the way home. I'm being led to think it's injector or fuel pump related. Any other ideas?
You know maybe it's just time to pull the head and while your in there...... do everything possible. She has been on duty for a long time.
Yeah I'm not quite ready to tackle that yet. Maybe this spring or summer. At least let me get this figured out so I can smog the darn thing.
I replied to your other thread. Mine had a different code but would run terrible until warmed up then no cel. Little know fact. There are grounds in your harness that ground to the ECM not the motor or chassis. No amount of ground cleaning will fix it. My harness wasn't damaged just a bad splice in the harness. 49 ohms from wire to chassis.
Bill McAnally Racing in Roseville has a 35 year experience master Toyota tech that can quickly diagnose any problem you're having for a very fair price. After months of testing feeling defeated I took mine in. Cost me $150. After spending 60 hours and $800 in parts with no success I felt pretty dumb for being so stubborn. It was fixed in a day for $150. On a positive note I have a high mileage 80 and the new parts made it run like a champ.
Thank you for all the info. I will give them a call tomorrow and see what they can do for me. Is there a certain person I need to ask for? 150$ to figure out my problem is well worth it. My time is much more valuable. Just knowing what it is will be 99% of the battle. I feel I can fix just about anything. Diagnosing on the other hand has got the best of me this time
OBD 1 is near impossible to diagnose on most vehicles without experience on that vehicle. I think the guys name is Mike. I could be mistaken. He's their only yota tech.
Post is too long to reread to see if you checked the plug connectors.
I had corrosion in one of my plug connectors. The corrosion worked its way up the wire under the wire coating. Had to cut back the wires till I got clean wire.
