Intermittent code 26
Middle part of the pic is the list of stuff that causes 26
View attachment 1394591 Middle part of the pic is the list of stuff that causes 26
thanks.
Were both pretty sure its an injector. by the readings he gets its coming from one of the front 3.
What should I do guys? replace the front 3 and see if that fixes it, or remove all 6 get them tested and serviced and go from there?
I cant make up my mind.
I've changed just the one bad injector or do them all, pretty easy to do yourself, get new Orings when you change them, make sure once fuel rail is bolted back on that they rotate, and also make sure you plug them all in if you break a plug clip u can use some rtv on it that will hold them tight
Not hard really, you just need 30-36" of extensions. I can't recall having to remove anything to get to them. Maybe the tranny dipstick, thread some wiring harness sorts of things. It is far harder cleaning it up than removing it.
That's good to hear I was psyching myself out.
latest update:
CEL hasn't come back on once since the other day. Took it to get smogged and it failed due to the EGR not getting any vacuum. Smog tech said the solenoid underneath the plenum is where the part is. That is the PAIR valve correct? My timing was also off by 3 degrees. Sniffer was no problem, but due to California's dumbass laws he had to fail me. So I guess when I rip the top off to get the injectors serviced I'll test the PAIR valve and or replace it.
latest update:
I think that's the vacuum solenoid valve if yours is the same as my '97.
I would try to do some tests first to see what the actual problem is. It could be that the vacuum just isn't reaching the valve. It could also be the modulator valve that sits next to the EGR.
Modulator valve and egr are functioning correctly. The tech confirmed that for me thankfully. It's the vacuum coming from the upper plenum to the EGR itself.
ME BACK ON
Modulator valve and eve are functioning correctly. The tech confirmed that for me thankfully. It's the vacuum coming from the upper plenum to the EGR itself.
Ah, is that pesky tube going through the plenum clogged up?
The PAIR valve lets air from the air cleaner go into the exhaust manifold. Has nothing to do with the EGR but if you look at the vacuum hose diagram some of the hoses connect from one system to the other.
The VSV opens and closes vacuum to the EGR to open and close it.
This is the Port that is Not giving off any vacuum.
I sprayed some maf cleaner in there and it was killing the engine while running so it's not clogged.
I think that is the VCV for the EGR. only $110 :/
latest update:
FYI... the 93-94 ODB1 vehicles have 4 VSV's under the intake manifold
1) VSV for EVAP which controls the venting of the charcoal canister
2) VSV for Fuel Pressure Control
3) VSV foe EGR
4) VSV for PAIR
3) VSV foe EGR
4) VSV for PAIR
I'm assuming it's the VSV for EGR. But I haven't taken the top plenum off yet to test them all.
The VSV for the EGR is a tiny electromagnet attached to a tiny diaphragm that opens and closes the vacuum to the EGR.
thanks
looks like that's exactly what I'll be needing. I am going to start taking stuff apart tomorrow. I will test all of the VSV and solenoids while I'm in there.
So I got it all taken apart. Sending the injectors out this week. Think this may cause an issue?
Should I remove the lower Intake for any reason? Or just leave it?
I'd pull the lower and clean all the carbon out of both halves since your there
Now is a good time to replace your faulty injector, if it is indeed broken and have the other 5 cleaned.
